It's not catalytic convertors that produce water, it's the burning of the fuel/air mixture.
+1
Exhaust gas, with or without an oxidizing catalyst (HC & CO), a reducing catalyst (NOx) or a three way catalytic converter (HC,CO & NOx) is a mixture of highly corrosive chemicals. The presence of Water (H2O) has little to do with the generation of Rust (FeO2). If you don't want rusted exhaust systems, you'll need to use stainless steel.
Will be looking to change pipes over to something with a growl instead of the quiet pur of standard pipes soon as i can find some at the right money here in tokyo.
You'll almost ALWAYS do better (in most cases, MUCH better) importing parts from the States.
