Brake master cylinders is going to have some serious fungus,
you will find one little problem one after the other, don't get frustrated; you will have a nice sled after a bit
change all the fluids, flush out the fuel system, and clean out the tank.
add a new battery, check the tires, and run it.
It's got a kicker, so give her at least 10 to15 decent strokes (with the coil disconnected)along with the gas petcock in the OFF position just to get the oil where it needs to be, then get serious and jump on her, get her started and take her out for a spin but be relatively easy for the first 1 to 5 miles.
