I bought myself a second head pipe so that I could decat this one and still have a stock pipe if needed. I cut the window out of the head pipe and removed the cat material. My question is this. Do I have to ensure that I get every bit of the material out? I ground what I could but it still feels like there is still some in there flaking off the pipe. Do I need to worry about getting every last crumb out? if one of the flakes that I leave in there breaks off the pipe, will it harm the bike or just blow out the exhaust? Adding monster ovals also.
I know this this sounds like a dumb question but I am not that that mechanically inclined and don't feel like screwing up my 21000 dollar toy.
put your hand over the exhaust on a harley sometime------------they have a slight bit of overlap in the cam and you can feel a quick bit of suction but I dont think it could draw it all the way up the pipe before it fired again but I would sure try hard to get it out to keep from getting another rider in the face with super hot junk myself.I dont think you can get it perfect but pretty close
I would try to remove as much as possible. I don't know how far the cats are down the pipe for reversion to cause a problem, but i know cager cars that have the cats close to the head (bolt directly to manifold) can have problems with the piston oil rings getting clogged with debris from cats that break apart. nissan sentras in general had a big issue with this problem.
try putting a bunch of 1/4-5/16 nuts in cat chamber and shake around to knock off as much as the loose stuff as possible.
I did mine and agree there will be smalls chards attached to the inside of pipe. I doubt they would ever be an issue and may even burn away over time. I wouldn't worry about it and just enjoy the reason you did it in the first place.
Convertor "material" is CERAMIC! It does not burn away, and indeed can be injested (by reversion) back into the engine! NOT "getting it all" can lead to engine failure!
On cars with even underfloor cats, I have lost engines (development) when convertors failed!!!
Reversion is greater with few cylinders! More time between firing pulses in the exhaust. A 6 has more reversion than an 8 and a 4 more than a 6, so you can imagine how much more reversion is present in a 2 cylinder NON_EVEN firing Harley!!
Ceramic makes an excellent abrasive!
Have you ever seen the guts of an HD convertor? The substrate is stainless steel, (mine certainly was) not ceramic. I realize some automotive convertors are ceramic, HD is not.
Suggesting that there is adequate reversion to draw material into the cylinders is ridiculous and physics/engineering calculation can prove it.
You would have to draw a volume of exhaust greater than the volume of the header pipe back up to the cylinder and into the chamber while at the same time drawing intake air into the other side of the cylinder.
Your information falls along way short of "factually accurate". Maybe check your facts before posting info that confuses people.
