Power commander
Old Nov 28, 2012 | 05:44 PM
Lez the Ted's Avatar
Lez the Ted
Stage I
Cool Power commander
Hi All
Just fitted a pair of zodiac copy 'Balony' cut muffler's to my 2007 'streetbob' , Do I now need to fit a Power Commander to ensure the fuel metering is correct or will the stock fuel injection system be ok ??
Old Nov 28, 2012 | 06:01 PM
fdb2007's Avatar
fdb2007
If you didn't do anything to the intake, you are fine. If you did the intake most will say yes to some sort of adjustment be it a aftermarket tuner or a reprogram by the dealer, some will say no because the ECM will adapt on its own. I can't give you a straight answer as I am not sure what the right one is. I have only done remaps from HD and they have worked fine for pipes and a breather on an '07 and a '10 with cams and a big bore kit. Do a search on this site, there are more opinions and some facts than you can read in an evening. Good luck with getting a straight answer.
Old Nov 28, 2012 | 06:41 PM
MYCRISIS's Avatar
MYCRISIS
By relieving backpressure caused by mufflers you have not changed your intake mixture. Short answer is no, you do not need to remap for a muffler change. Adding a high flow air cleaner/filter might lean out an already too lean from factory condition and I would then remap accordingly.
Good Luck. I hope you like the sound.
Old Nov 28, 2012 | 07:17 PM
Guitardude's Avatar
Guitardude
Originally Posted by Lez the Ted
Hi All
call the folks at Fuel Moto, nice guys and they can walk you through your options and tell you the pros and cons of each.
kcollins
Mar 14, 2017 01:38 PM
joey883
Feb 10, 2013 09:53 AM
kalamitty
Apr 13, 2012 12:42 AM
Redbob 07
Apr 10, 2009 10:29 AM
Tat2u
Sep 21, 2007 06:28 PM
