Moved my enrichener
Moved my enrichener
It's been pretty cold for several weeks now and I have been having to use my enrichener every time I go anywhere. When it's warmer I can usually push it in before I leave the driveway.
After all these years on this bike you'd think I would be able to find it after I'm rolling without having to look but that's not the case.
I decided I wanted to move it someplace a little more convenient and started looking for a good option.
I found a little gizmo made by CV Performance and just finished putting it on. I have one of their EZ Just air fuel mixture screws and it is good quality as is the relocation kit for the enrichener.
http://www.cv-performance.com/
I think it not only will make finding it easier but I like the way it looks on the bike as well.
I have a 2" tank lift and it has just has enough clearance to not hit the tank as you can see in the pic below. If I didn't have room they include a couple nuts that allow you to mount it under the carb cap and that would allow plenty of clearance.
As far as mods go it was pretty cheap and only about a half hour to put on. You have to remove the carb to do it.
Nope. The website said you might need to use a shorter cable if you place it underneath but Mine seems to work fine. It didn't come with any instructions but pretty self explanatory.
Received 3,963 Likes
Cool deal. Like said, that is a better place for the factory to put it anyway.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
