very stupid question
Old Feb 11, 2007 | 03:43 PM
eleutheros's Avatar
eleutheros
Default RE: very stupid question
The only thing to worry about is riding the clutch. That is holding it halfway too long, or having it adjusted too far out. I don't always release it perfect, that is changed gear, gas and slow release, but never had a problem except with every Honda I've ever had (4), worse in the 60's and 70's. I'm told motorcycle clutches are made for much more use than cages.
Old Feb 11, 2007 | 04:11 PM
UncleMike's Avatar
UncleMike
ORIGINAL: SpeedsterX
Dude!!
It's like sex.
Get a feel for it first. If anything you're doing "seems" too fast or too slow,,
then ease off or hammer it alittle more.
The engine will "tell" you what it needs as you're going through the progression!
Just don't give it TOO much gas prematurely!
"Cause that would be PREMATURE E-GASULATION!!
(and nobody wants THAT!!!)
[IMG]local://upfiles/4802/D6E62CE761534E588110FEB183C9B3F6.gif[/IMG]
PREMATURE E-GASULATION... One sick little Kitty. LMAO
Old Feb 11, 2007 | 04:13 PM
rdam's Avatar
rdam
When I first learned to drive a stick, I was taught to keep my foot on the floorboard unless I was actually shifting. Even at a traffic light, I wouldn't drop into first until the light turned green. In 24 years of owning standard shift trucks with over 130,000 miles on all of them, I never replaced a clutch.
I think MSF teaches to hold in the clutch while in first gear at a light, in case you need to "escape", and that argument certainly holds merit. However, I do think the "keep your foot on the floorboard/hand on the grip (not clutch lever)" is sound advise. In recent years I have learned to operate in the "friction zone", while dragging the back brake, in order to do slow speed manuevers. This goes against whatI have traditionally done for years, but there is no doubt that this skill is a MUST in order to operate these large bikes at slow speed.
So, learn to ride properly. Take an advanced riders course, and don't worry about it. Cluthes are relatively cheap anyway.
Old Feb 11, 2007 | 04:16 PM
BigJfxdwg's Avatar
BigJfxdwg
I guess I've never had a clutch problem in after alot of miles and bikes over the last 15 years.
But this got me thinking, may we don't need to use the clutch at all. after you get going just shift witout the clutch, I'm sure that will be more smooth. [sm=confused06.gif]Clutches are an elaborate plot by the MoCo to suck more money from our pockets.
Old Feb 11, 2007 | 04:30 PM
glebo's Avatar
glebo
Dude!!
It's like sex.
[sm=funnypostabove.gif] thats a good one. Its like driving a standard in your car, dont abuse it or ride or slip it and it will last you a long long time.
Old Feb 11, 2007 | 10:02 PM
gliderider's Avatar
gliderider
ORIGINAL: dmr
well, you should ease out(disengage) the clutch while applying the throttle. try not to "bang" gears. when you do that, you chew the clutch a bit. on other thng, try not to ride with your left hand on the clutch lever. if you are, you may be inadvertantly pulling the clutch lever in slightly (engaging) whichwill also cause some wear. just some thoughts
Not trying to be a grammar ****, but I think you've got the terminology backwards.
When the clutch lever is pulled in by your hand, i.e. touching the grip, the clutch is DISengaged.
When the clutch lever is free (your hand is not squeezing it) the clutch is ENgaged, that is, transmitting power from the motor to the transmission.
If you DISengage the clutch while applying the throttle, you'll make a lot of noise but you won't go too far.
OK, enough of that.
I agree with the poster who said just act natural, or words to that effect. I started riding on small dirt bikes many years ago, and I think that is a good way to get to feel one with the machine. That, to me, is what is necessary to ride well.
Old Feb 12, 2007 | 12:11 AM
Unamed's Avatar
Unamed
ahh hell jsut rev her up and slip your fingers off the clutch when she starts to shake!
escalade6103
Apr 30, 2015 11:06 PM
mehurr
Dec 28, 2010 03:48 PM
shiftharder
Sep 28, 2010 07:11 PM
pauletich
May 11, 2010 10:25 AM
dog155
Aug 15, 2007 08:49 PM
