Bike's Running Rough
Old Feb 12, 2007 | 10:30 PM
johnsonabq's Avatar
johnsonabq
Default Bike's Running Rough
I posted this in the Sporty section, but then I thought I should post it here...
Ever since I got the SE air cleaner installed along with the download, I've had some problems with the way Sporty runs. It's usually fine, but sometimes when cruising downtown at around 25 - 30 mph in 2nd or 3rd gear she'll run rough. Missing, sputtering (short ones), sometimes a gag or cough with a phhtt coming from the air cleaner.[:@] I was hoping to get a few ideas as to what it is before I take her in for the 5,000mi maintenance. I hope the dealership doesn't give me a hard time about it. This never happens at higher speeds in higher gears.
What do you guys think?
Thanks!
Old Feb 12, 2007 | 10:59 PM
wesd41's Avatar
wesd41
Default RE: Bike's Running Rough
You're getting good answers in the Sporty section. Check your plugs first, replace if fouled, see if the problem returns.
If not fouled, take it back where you had the download done and tell them to fix it.
Other things to give the once over- spark plug leads and electrical connections in your ignition and fuel injection wiring. Something may have loosened up, or got knocked loose during the SE install.
Old Feb 13, 2007 | 12:50 AM
Mikey 1450's Avatar
Mikey 1450
If its spitting back out of the airfilter at slower Rpm's, after the engine ishot, sounds likeyourlean on the bottom. Take it back to the tuner.
Old Feb 13, 2007 | 01:09 AM
johnsonabq's Avatar
johnsonabq
Does this apply to EFI also?
Old Feb 13, 2007 | 01:17 AM
wesd41's Avatar
wesd41
Yes.
Our07Ultra
Jun 25, 2017 10:41 PM
voudoujoe
Mar 15, 2014 01:13 PM
Hound Dog 1
Jun 28, 2007 06:13 PM
johnsonabq
Feb 13, 2007 09:08 PM
bohica48
Sep 15, 2006 04:23 PM
