using oil
Old May 9, 2013 | 11:11 PM
e_minor_pentatonic's Avatar
e_minor_pentatonic
Default using oil
I had a friend tell me his dyna is using oil, bout a quart ever 1000 miles. I've always traded before this happened. How consented should he be?
Old May 10, 2013 | 12:02 AM
scasey's Avatar
scasey
Dealer would say that is normal but I laugh at that.
Old May 10, 2013 | 07:07 AM
Def Mute's Avatar
Def Mute
"How consented should he be?"
I'd hope he consented to you asking this question...
But, if you meant 'concerned', then that's up to him I guess. Maybe he has disposable income and doesn't care for the bike much more than how fast he can get a 'good deal' on a trade in, much like yourself.
Or, if the bike means a little more to him than yours does, then he could get a service manual, a few tools, and learn how to tell you what you are missing as part of the completion to your biking experience...
(I could have elaborated on how to diagnose his oil consumption problem(s), but you probably would have screwed the message all to hell with your lack of concern over how to repair a perfectly good machine which you might consider nothing more than used up refuse to be passed on to some low life grease monkey like me. )
Old May 10, 2013 | 10:32 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
A quart ever 1,000 miles? That seems like way too much. A quart ever 10,000 miles sounds better. But that could be wrong too.
Old May 10, 2013 | 10:45 AM
hyde802's Avatar
hyde802
What year is his bike/how many miles? Im going through this now with my 05
Dealers will tell you that a quart in 1k is ok. But I call BS on that one. Thats a ton of oil going through 2 small cylinders..
Old May 11, 2013 | 06:42 AM
oct1949's Avatar
oct1949
Is it smoking,?? leaking,?? or what.??.
pends on what the total pic is.!!
U might want to lean to put in a little more info about the bike when asking a question in here...
We can't read Ur mind..
Old May 11, 2013 | 06:58 AM
doug62's Avatar
doug62
Is he using synthetic or conventional oil? My Honda VTX 1800 uses oil when I have synthetic AMSOIL in it. Every 1500 miles or so I have to put a full quart in. When I switch over to conventional oil it doesn't use a drop.
Old May 11, 2013 | 07:14 AM
Ted Tyler's Avatar
Ted Tyler
My 05' super glide uses oil also Harley used different valve seals half way thru the year in 2005 and found out they didn't work, my bike burns oil but not a qt. to 1000 mi but i have put a qt. in to 2,500 mi the dealer told me about the seals after i brought it up to him.
my son-n-law has a later 2005 road king and don't burn oil
Old May 11, 2013 | 09:31 AM
KEYBEAR's Avatar
KEYBEAR
I have never had a bike use oil ever . My last Harley would be down a pint in 2500 miles . If your using more then that find out why ?
Old May 11, 2013 | 06:44 PM
e_minor_pentatonic
Talked to my friend again today and he is using mobil 1 synthetic. The bike doesn't seem to be smoking and is black inside the exhausts. It is a 1995 Dyna with aprox 50,000 mi. I have owned 4 Harley's and have never had this problem. I had a 72 once that slung oil everywhere, but that was the chain (do you remember those days?). The most miles I ever put on one was about 70,000 and never had this problem.
VASportster
Jul 4, 2011 11:18 AM
Mgarrett88
Aug 30, 2008 11:21 PM
BigGeorge
Oil Archive (no new posts)
Aug 9, 2006 07:57 PM
clayshooterwv
Jul 6, 2006 04:34 PM
CobraKid
Exhaust System Topics
Jun 6, 2005 11:19 AM
