electrical issue
Old Jun 27, 2013 | 08:53 PM
hdfire70's Avatar
hdfire70
2nd Gear
Question electrical issue
Hey Guys. I'm having an issue with the headlight on my Sporty. Its a77 and I had to practically rewire the whole bike since the last owner decided to butcher it. My problem is when I start it, the headlight will work just fine, but when I ride or even just rev it up a little, the lo-beam will dim right down to nothing. The hi-beam doesn't get effected at all. Just the lo-beam. Did I mess something up with the wiring or maybe weak regulator, battery? I usually ride with the hi-beam anyway but would like to get the issue fixed. Thanks.
Old Jun 27, 2013 | 09:15 PM
Coastal CVO's Avatar
Coastal CVO
Have you checked it with a volt meter to see if the voltage is really dropping or if the vibration is causing the element to fail?
Old Jun 27, 2013 | 09:22 PM
Coastal CVO
You should have dual element bulb, this requires 3 wires, 1 for low beam, one for high beam and one for ground. Make sure they are in the correct order or you could be loosing ground which would cause it to seek ground thru the high beam element. That could cause the symptom you discribe as well.
Old Jun 27, 2013 | 09:46 PM
TwiZted Biker's Avatar
TwiZted Biker
This , it's easy to mix up the wires .
Veekness
Sep 29, 2014 07:26 AM
Stevieskull
Nov 17, 2011 02:19 AM
MoosesUltra09
Oct 18, 2011 12:07 AM
goose136
Electrical/Lighting/Alarm
Mar 6, 2010 10:21 PM
nicko99
Sep 12, 2007 10:52 AM
