Advice?
Old Jul 8, 2013 | 01:54 PM
jakenok's Avatar
jakenok
Originally Posted by Kowan
According to HD, those bolts are a one time use and replace with new ones when removing the sprocket.
People on the forum have stated they've reused the old ones.
So I suspect the previous owner tried to save a few bucks that you're going to end up paying for.
This.If you google "broken bolts rear pulley harley" you will find more than a few stories about this.
https://www.hdforums.com/forum/dyna-...ley-bolts.html
Old Jul 8, 2013 | 01:56 PM
ajmilberg's Avatar
ajmilberg
Originally Posted by Def Mute
OK, I'll ask, since no one else has yet...
How did you figure out there were grade 5 bolts used instead of grade 8? If they sheared off, the heads of the bolts where the identifying marks are, should be splattered all over the highway. Did you go back and find them? And, on second thought, they should have been allen or torx head bolts. Not sure how the markings are placed on those if at all...
Amazingly enough I found one of them, part anyway, and it was enough to identify the grade. The independent shop that's doing the repairs uses at least grade 8, or if request aircraft grade, and mark them all as well.
Old Jul 8, 2013 | 02:04 PM
dribble's Avatar
dribble
Originally Posted by AZRenegade
I suspect you are barking up the wrong tree on this one. As stated above, unless you specifically requested pulley maintenance, there is no reason for the tech to remove the bolts during a routine tire change. And if they, for some reason did, why would the tech go out of his way to use a lower grade bolt when the correct ones are in stock? Also, if the bolts were replaced by the tech, your invoice would have the charge for the removal of the pulley and new bolts listed. A more logical reasoning would be that the previous owner is at fault. Somewhere along the line the owner probably removed and replaced the original bolts with an inferior grade while in the process of customizing the bike or while in the process of decustomizing the bike in preparation for trade. That person's lack of attention to detail damn near got you killed.
They wouldn't. He would go to the parts dept and get the correct bolts. I believe you are correct. Plus there is no reason to remove the pulley when changing the rear tire. In any event, the tech notes should be on the RO in the file.
Old Jul 8, 2013 | 03:10 PM
oct1949's Avatar
oct1949
There is no reason to touch the pulley bolts on a tire change.
Therefore no reason to blame Ur dealer, If Ur looking to blame someone I'd look to the Prev owner. even more so if He changed out the pulley.
Old Jul 8, 2013 | 06:56 PM
ajmilberg's Avatar
ajmilberg
All that being said, anyone have a rough estimate on how much I'm looking at for repairs? Independent shop out here is awesome and way less than an hd dealer, but I'm sure this isn't a simple $200 fix.
jeffbetrollin
Jul 26, 2015 05:46 PM
Gommee
Jul 3, 2015 10:13 AM
gadawgsfan
Nov 18, 2009 10:38 AM
un3asyrider
Oct 13, 2009 03:41 PM
lilrooster76
Oct 8, 2008 02:16 AM
