Obsolete Generator bolts??!!
Old Jul 23, 2013 | 01:52 AM
Jamz's Avatar
Jamz
You'll screw the pooch if you jam those in there , threads are US standard in the generators . Think they are 5/16" fine thread if I remember correctly .
bottom bolt buttoned up nice, but, top just gets finger tight but then just started spinning - that's how the top bolt acted before I put this new bolt in though.
I added some plumbers tape to it, and it seems to have helped.
If it turns out that the one bolt is causing the generator to pull off, I will just buy a replacement generator, I guess....
Old Jul 23, 2013 | 01:53 AM
Jamz's Avatar
Jamz
going to refill the oil to proper levels and give the bike a run tomorrow to see if the generator pops off or if I get any new leaks.
Old Jul 23, 2013 | 04:54 AM
olskoolblu's Avatar
olskoolblu
Sounds to me like a previous owner damaged the threads. You'll have that with the older bikes.
Old Jul 23, 2013 | 05:29 AM
Very High Plain Drifter's Avatar
Sounds like a stripped thread to me. Are new generators expensive?
Old Jul 23, 2013 | 08:26 AM
TwiZted Biker's Avatar
TwiZted Biker
Longer bolt or helicoil if you don't want to spend the money for new , there's tons of used ones around if you want to dig just look hard at the holes for the same problem .
Old Jul 23, 2013 | 08:33 AM
big cahuna's Avatar
big cahuna
Don't know if there's one by you, but Sears hardware by me has a big section of nuts and bolts. Black, plated, stainless, metric, just about everything you might need. Including different grades. Worth a try if there's one around.,,
Old Jul 23, 2013 | 03:45 PM
Jamz's Avatar
Jamz
about $100 on ebay
Old Jul 23, 2013 | 03:46 PM
Jamz's Avatar
Jamz
I usually hit up Ace hardware or HomeDepot for bolts and such - they generally have a ton of variety.
Old Jul 23, 2013 | 03:47 PM
Jamz's Avatar
Jamz
Heli-Coil might be the better option..... and thinking about it now, I should have some helicoils in my toolbox.... we'll see how it goes.
Old Jul 23, 2013 | 03:51 PM
brownfoxx1's Avatar
brownfoxx1
when you get your new bolts, drill holes thru the bolt head & saftey wire them, so they won't vibrate loose.
