View Poll Results: In gear at light or neutral at light
In first gear at light
80.00%
In neutral at light
20.00%
Voters: 295. You may not vote on this poll
Poll Leave in first gear at light or neutral at light?
Old Aug 13, 2013 | 01:18 PM
johnjay's Avatar
johnjay
1st gear unless I know the light is long or I have no escape route.
Old Aug 13, 2013 | 01:20 PM
Dogshark's Avatar
Dogshark
Neutral cause thats what my pops taught me when driving a car. He told me it was bad for the tranny to stay clutched in for long periods.
Old Aug 13, 2013 | 01:29 PM
soft 02's Avatar
soft 02
Its only hard on the throw out bearing but today's throw out bearings last longer than a clutch. It was somewhat true back then.
NDBadlands4-2's Avatar
NDBadlands4-2
The only light I will shift to neutral for is at a railroad crossing, while waiting for the train. Then I would shut it down as well.
Old Aug 13, 2013 | 02:33 PM
Walter White's Avatar
Walter White
Originally Posted by danzio
Can't vote. You left no option for both. Sometimes I stay in gear and sometimes I like to be in neutral. Depends on the intersection and the length anticipatied for the light.
I do this too. I also keep it in gear until I have a vehicle stopped behind me then neutral. If I didn't I would have a popeye sized left forearm on some of the rides through town.
Old Aug 13, 2013 | 02:38 PM
roadking2000's Avatar
roadking2000
Do you put your car in neutral at a light? I leave it in first always. You can't go anywhere in neutral.
Old Aug 13, 2013 | 02:49 PM
FDHOG's Avatar
FDHOG
Been driving a stick for 40+ years, and yes I do put it in neutral at a light, and where are you gonna go, it's a red light.
With the bike, I leave it in gear until a car pulls up behind me and stops, then it goes into neutral. For all you guys that leave it in gear for fear of being rear ended, are you constantly looking in your rear view mirrors and nowhere else, cause if you're not, what's the point. You'll be hit before you can do anything about it whether you're in gear or not.
Leaving the clutch pulled at a light causes more unnecessary wear on your throw out bearing and for the post above that says the bearings last longer than a clutch, do a search on throw out bearings.
Old Aug 13, 2013 | 02:53 PM
smudge's Avatar
smudge
No brainer...leave it in gear and watch your mirrors in case some **** runs right up yer ****. You may have to make a quick getaway so leave yourself an escape route too.
Old Aug 13, 2013 | 03:00 PM
Bayfield Cty. Biker's Avatar
Bayfield Cty. Biker
Default stop light
Leave it in first gear, just in case you have to bolt from a inattentive driver. Yeah........that never happens!
Old Aug 13, 2013 | 03:03 PM
soft 02's Avatar
soft 02
Ive replace 20 clutches for every 1 throw out bearing that was bad but this is on trucks mostly. Cars may be a different animal.
