Mikuni Carb
Old Sep 5, 2013 | 10:43 PM
magnum629c's Avatar
magnum629c
Originally Posted by Uncle G.
Are you asking me or the OP? In my case, I'm running a #20 pilot/air screw 7/8 turn out (I had a 17.5, but it would cough in cold weather), #98 needle (center notch)/#165 main jet/#50 accelerator pump jet (pump rod set to "no" gap).
Motor is stock internally with Arlen Ness "Big Sucker" air cleaner and H-D by Kerker 2 into 1 exhaust and muffler.
Bike runs really well with this setup.
I guess I was asking u both. That's a nice setup Yea the 17.5 is a tad small. I had that same jets but now moved up to a andrews 21 cam... Let me tell us that 21 cam and the mukuni are some combo. That andrews 21 cam is a monster down low of torque best 600$ I ever spent
Old Sep 7, 2013 | 06:06 AM
FLoTR's Avatar
FLoTR
Thanks for the info. I'm not sure how its set up now because I just bought the bike 300 miles ago. Don't know what cams it has either but it seems to start breathing good around 3800 rpms, (pulled away from a 380HP Dodge Challenger). Runs really smooth, just seems kinda cold natured and I keep having to adjust the idle, which seems best around 1150/1200 rpms. I'll get that PDF, thanks people.
Old Sep 7, 2013 | 07:19 AM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
I have same 95" Dyna with SE heads and it gets around 50 MPG and runs perfectly(96 HP). They used to come with a "mileage kit" in the box and i used it. It was just a couple of jets and another needle. Sounds like you may have something like an Andrews TW55G. That's about the RPM mine takes off.
Old Sep 8, 2013 | 08:21 AM
FLoTR's Avatar
FLoTR
Truckerdave, I love to hear a V-Twin screaming at 6k rpms. Gas mileage??? Last tank was 38. Probably need a new air filter, and a little less wrist;-)
Smartbass
Jan 13, 2016 08:35 AM
massparanoia
Oct 26, 2015 08:43 AM
parts eeter
Jul 30, 2014 01:27 PM
falconbrother
EVO
Feb 8, 2013 03:43 PM
raven28690
Ironhead
Mar 5, 2007 12:06 AM
