thanks for the response!!
still don't understand why Harley doesn't use syn3 in all new bikes
For the same reason auto manufacturers don't use synthetic oil as factory fill on the average new vehicle.
Auto manufacturers save the synthetic for their more premium sports cars, same as HD uses synthetic on the CVO 110 engines.
I prefer breaking-in new engines with dino oil. When I bought a new BMW bike about ten years ago, the dealer told me to run non synthetic oil in it until it was broken-in, about 20,000 miles. There's nothing wrong with non synthetic Harley oil; I ran it for about 1,500 miles after I did my 95" build. Enjoy your new bike and try not to worry too much.
If you look on Harley's website at the syn3 it says that you can use it during all stages of engine life, including break in. I'm not trying to start an argument, but don't listen to people from northern climates that tell you your Harley won't benefit from synthetic. You live in Texas like me, your bike will definitely benefit from synthetic due synthetics ability to control heat better than dino oil. I won't run anything other than synthetic in my bike or truck.
I agree with you. The manual says it`s excellent for extreme temps, hot or cold. Where I live, it might get into the 90`s maybe 10 days for the summer during which I probably am working and as far as the cold weather, no thanks below 45 degrees. So for me, it`s HD dino oil with no regrets.
Problem with running synthetic in hot climates is that due to it's heat transfer properties Synthetic will run about 10 degrees hotter than dino oil.
We had a long lengthy argument about heat transfer in oils and I lost the argument. I read the data and tried it in my bike and sure as hell it's true. Synthetic oil will transfer heat from the engine more effectively than dino oil. Therefore it runs hotter.
To me, it's a bad thing to have your oil running too hot. Under all indications, you should stick with good ol dino oil.
I run Synthetic in my Diesel truck, but with the high compression and the turbo, it's a requirenment. The Harley doesn't have those high specs so they don't require that level of oil. But they will glady sell it to your for the extra bucks.
Run your bike at least 1,000 miles then change it yourself. There are a lot of us on this forum that do are own oil changes. I use Mobil 1 V-twin, others use various popular name brands. Doing the oil change myself cost me about $50.00 including filter and gaskets.
Im on my second Harley. Just got my Heritage new back in March. Ran the bike till almost 1,200 miles then changed it myself. The bike does not explode if you go over a little and if you wait to switch to synthetic after the first 1,000 miles. I think lot's of people waste money changing their oil before factory recommended mileage. Hell with Mobil 1 I'll probably wait till I get just past 5,000 miles before I begin to think about it.
I only switched to Syn-3 on my FXST because in the winter, when it got down in the 20s, the bike would be hard to start.
Read up on it and asked the service manager, and he agreed syn would help it start easier in the cold weather. The trade off is that you may notice valve noise (I did) and once you put in syn, you really shouldn't go back to dino.
Other than that, like Zeus pointed out, I have noticed my oil tends to run a tiny bit hotter in the summer, but also a little cooler in the winter. It seems to want to take on and give up heat much easier than dino oil.
