Always use the kill switch, that's what it is for. Never have forgotten how to turn motor on and off.
No, the "kill" switch is there to enable you to shut off the motor when the bike is lying on its side after going down, and you can't reach the ignition switch, because it's somewhere between the bike and the ground.
I haven't used the kill switch since I started riding street bikes in '81. On my dirt bikes, I had to, because they had no ignition switch.
You guys who talk about it being for emergencies when the bike is on the ground do know that Harley and every manufacture of street bikes out there have a built in safety that kills the bike if it goes over, right?
Guess you guys never rode old bikes that didn't have kill switches. I never use it.
A lot of the old bikes I rode (mx and enduro) never had ignition, kill switch only. Consequently it's kill switch off, motor dies, kill switch back on, ignition off for me. When I took delivery of the streetbob was told to use this procedure as well. And owners manual says so too. Was something to do with ECM doing post shutdown checks while the ignition was still on? Dunno. Anyway, just force of habit with me.
Who really cares how ya do it? Whatever works for you.
thank you, surprised it took 4 pages for that and I know it works from experience. I use the ignition switch for no particular reason other than habit. For me, the kill switch is the battery kill switch since about the only time I use it is when pulling up on a trailer and into a wheel chock.
I seldom use the kill switch on a Harley with a tank mounted ignition switch, habit I guess. Might flip it to the "off" position if I go in somewhere and leave the locks unlocked.
Some bikes, it doesn't make sense to use kill switch, my XR1200 & Buell S3 have the ignition somewhere else than the tank, always key operated, so it's a done deal.
I started riding old bikes that did not have a kill switch.
Can somebody explain the benefit of using the kill switch when I really am only wanting to turn off the bike.
To me it seems like the kill switch is for emergency situations?
By using the kill switch you can turn off the bike while both hands are covering the clutch and brake. Its a safety thing.
Kill switches were first required on motorcycles when the ignition switches were on the left side of the bike and not visible to the operator. Back then, bikes would sometimes "run away" due to a kinked throttle cable on pre-CV carbs or possibly pre ignition on a carboned-up two stroke. I've had both happen to me. I don't use the kill switch, because it's redundant and I always put the bike in neutral before shutting down, but I don't fault other riders for using theirs.
