If you don't use the kill switch, it is that much easier to forget to turn off the ignition switch. Then when you get back to your bike, you have a dead battery.
So if you don't use the kill switch, you have to use the ignition switch. How does that then make it easier to forget to turn off the ignition switch ?
The kill switch seems like a bad switch to wear out with unneeded use.
You are going to have to turn off the ignition switch anyway. Why add another switch (the kill switch) operation to achieve what just one switch will do ?
Actually, they are not redundant at all. The ignition controls the electrical system of the bike, the kill switch controls just the motor. So when you use the kill switch, you are leaving the ECM to continue to process what's going on, and leaving the lights and radio on, and allowing yourself a minute to see if a code throws or anything else before you completely power down the bike.
My bike has no radio, doesn't "throw codes" and has no need for power to the ECM after the engine shuts down. Only rarely do I need to have the lights turned on with the engine off. In all my years of riding, I can't remember having ever used a kill switch to shut an engine off during or after normal riding. The first few bikes I owned didn't even have one.
First of all I have been riding bikes longer than all of you because I started out with a stone wheel with a wooden shaft running through it. Back then we wore loin cloths and clubbed our food. So the rest of you need to use my "old school" start up routine.
First I dance around the bike in my *** less chaps swinging a dead snake over my head. I can't believe the rest of you do not do that as it wards off the evil pirate spirits.
Then I cuss out the Ol's cat for allowing his fur to float around the shop.
Then I remember I will get arrested if I do not go back in the house and put my pants on under the chaps.
Then I go back in the house an get the flippen key fob I forgot again. I know this because my turn signals are flashing for the five thousandth time as I push the bike out of the shop.
Before one of you smart azz know it all types tell me I should start the bike in the shop I cant. It frightens the aforementioned cat. When the aforementioned cat has been frightened I am cut off by the aforementioned cat's owner. That is sad and unfortunate.
Then I look back for the oil leak on the shop floor to judge if the size of it has increased enough for me to add oil. I guess that is a hangover from the AMF days and I just cant shake it.
Then I use my kick start. That means I kick the hunk of crap in the tire and tell it if it gives me any back talk I will run over it with my tractor and collect the insurance money.
Then I turn the little thingy to the right and click the little thingy down and push the other little thingy. Sometimes if I preformed the snake over my head thing correctly a loud noise occurs.
Then I get ready to throw my leg over the beast.
Then the OL comes around the corner of the shop and asks if I am going riding before I finished whatever the buzz kill project of the day is.
No, the "kill" switch is there to enable you to shut off the motor when the bike is lying on its side after going down, and you can't reach the ignition switch, because it's somewhere between the bike and the ground.
I haven't used the kill switch since I started riding street bikes in '81. On my dirt bikes, I had to, because they had no ignition switch.
My bike automatically shuts off if it hits the ground. Don't ask me how I know
