Ignition vs kill switch
Old Oct 16, 2013 | 06:39 AM
  #61
dog155's Avatar
dog155
Another topic that always gets mixed reviews. Till I bought my first new Harley in 76 never had a kill switch why bother that is after all what the ignition switch already does.
To this day never think about a kill switch again why bother. Old Schooler
Old Oct 16, 2013 | 08:20 AM
  #62
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
If I use the kill switch, I forget to turn off the ignition.
Old Oct 16, 2013 | 08:43 AM
  #63
Phantom6722's Avatar
Phantom6722
Ignition switch only on both bikes, never had a problem stopping or starting.
Old Oct 16, 2013 | 08:45 AM
  #64
ringofld's Avatar
ringofld
Originally Posted by SoCalSoftailSlim
I know you guys won't care, because you are all old school rebels. But from the HD manual:
*To shut the engine off, push the top of the OFF/RUN switch to the OFF position.
*See Ignition Switch. Turn the ignition switch to the OFF position to turn the electric power completely OFF.
Now, when you want to start your bike again:
*Put the engine OFF/RUN switch (6) in the RUN position and the transmission in neutral. Neutral (green) indicator lamp should be illuminated.
*See Ignition Switch. Turn the ignition switch to IGN and push the START switch to operate starter motor.
Seems simple to me to go by the book. But whatevs.
I may have to check again.
BUT I am pretty sure my neutral light does not function if the ignition switch is off????
Old Oct 16, 2013 | 09:43 AM
  #65
HDSAE60's Avatar
HDSAE60
dealer said on my 13 limited the idle setting in the ECM would be effected if I didn't let the rpm get stable before switching off with the run/stop sw. he said a lot of people have "high idle" because thay rev it up and turn off the ignition saving a false -0- in the ECM. I don't know if it's true but sounded good to me.
Old Oct 16, 2013 | 10:16 AM
  #66
jakenok's Avatar
jakenok
This is why I always turn off my ignition switch to kill the engine and shut off all electrical functions: batteries are not cheap https://www.hdforums.com/forum/gener...ery-180-a.html
Old Oct 16, 2013 | 10:40 AM
  #67
Mountain Cruiser's Avatar
Mountain Cruiser
What does your operating manual that came with the bike say? There you go....
Old Oct 16, 2013 | 11:18 AM
  #68
HDogg's Avatar
HDogg
Your 76' was a lot less complicated as compared to what they have on the current bikes.No fuel injection,CANBUS or ECMs that can go bonkers on you.
This is something I read of somewhere else too hence I have made it a habit to use the kill switch first before shutting off the ignition but having said that,there had been some embarrassing moments too.
Old Oct 16, 2013 | 12:20 PM
  #69
Scaredofrain's Avatar
Scaredofrain
Originally Posted by Crimson
I use the kill switch.. how do you keep jamming to whatever awesome tune that ALWAYS comes on right as you pull into the garage?
Best reason sofar!!
Old Oct 16, 2013 | 01:44 PM
  #70
GrandpaSpike's Avatar
GrandpaSpike
Well, I know of a dumb *** while riding through the Mojave Dessert on a ride from TX to CA got to day dreaming, changing hand positions and hit the kill switch. Finally, one of his riding buddies walked up and said "turn on the kill switch and let's go". Really embarrassing. Don't ask me how know about this story.
