Ignition vs kill switch
Old Jun 20, 2016 | 10:59 AM
  #161
skid_pimp's Avatar
skid_pimp
Originally Posted by Rogillio
Don't understand. Why would you have to shift it into neutral?
Just a wild guess, but maybe his ignition is down on the left side like mine, or some other less than accessible place that would require a hand not holding the clutch in...
Old Jun 20, 2016 | 11:17 AM
  #162
0maha's Avatar
0maha
Exactly right.
There are lots of bikes where the ignition switch is not reachable from your right hand.
All the rest is a bunch of old wive's tales. Use whatever you want. You aren't going to hurt anything.
Old Jun 20, 2016 | 12:32 PM
  #163
bdtaylor1979's Avatar
bdtaylor1979
I always use the ignition.
Old Jun 20, 2016 | 06:43 PM
  #164
RK4ME's Avatar
RK4ME
I understand the motherhood reason....just don't find that compelling.
I just told you why it's there. I don't care if you're compelled,or not. Actually,nobody does.
Old Jun 20, 2016 | 07:20 PM
  #165
'Ol dirty biker's Avatar
'Ol dirty biker
Originally Posted by Guitardude
I was taught to always use the kill switch when turning a bike off.
When starting it's always ignition on, hands on the grips, clutch lever in, bike in neutral, run/stop switch to run, fuel pump cycle complete and all lights off, engage starter...
When shutting down it's clutch lever in, run/stop switch to stop, ignition off.
I see a lot of guys that never use the "kill switch"...
Is that after you do a full walk around, check tire pressures, signal & brake lights, all fluid levels, and inspect for dings, dirt & bird ****? You put WAY to much thought into something so trivial. It's a bike not a rocket ship or airplane. For the record I use the ignition switch and haven't exploded yet but then again I use royal purple oil and put my gas cap on the pump when filling up so maybe that's why?
Old Jun 20, 2016 | 07:30 PM
  #166
Rogillio's Avatar
Rogillio
Are you always this emotional and hostile or is it that time of the month?
Old Jun 20, 2016 | 07:41 PM
  #167
Iron25's Avatar
Iron25
Old Jun 22, 2016 | 07:44 AM
  #168
japer1372's Avatar
japer1372
Originally Posted by yarg
If you don't use the kill switch, it is that much easier to forget to turn off the ignition switch. Then when you get back to your bike, you have a dead battery.
Exactly what I think. The previous owner of my bike told me to turn the bike off with the kill switch, and then turn off the ignition. I did that successfully for a month or two. One day I killed the bike, got distracted for one reason or another, and didn't turn off the ignition. Fortunately we were only at a bike swap meet for maybe 45 minutes or so. Got back to the bike, noticed the ignition was still on and was greatly relieved that the bike started right up.
If the battery had been dead, getting a dead battery bike started at a bike swap meet would probably have been a best case scenario....but what if we'd been in the middle of nowhere with no help and a dead battery ? That, could be a very serious issue.
So, that was the day I stopped using the kill switch and started using the ignition to start and shut down the bike. I'm going to make the assumption that Harley makes the ignition reliable enough to start and shut off the bike. Doesn't that just make sense ?
Old Jun 22, 2016 | 08:05 AM
  #169
japer1372's Avatar
japer1372
And God knows that the electrical and mechanical and safety engineers didn't know jackcrap about what they were doing when they stated that you should use the switch on the handlebars...
Just a guess, but my guess is that the instruction to use the kill switch on the bike to turn it off and on came from the legal department....not the engineers.
I sometimes think extra "necessary" steps are written into instructions for various products with the full knowledge that most people won't do them and if their product fails, misbehaves or causes injury, they can point to that procedure and ask you if you followed all 15 steps to start your bike ? Oops....I missed step 11 that said to check the oil level, so obviously not checking the oil level as specified in the starting procedure is what caused the malfunction of the wheel bearing that caused the accident :-) So, you see, we're not liable because you didn't follow the proper procedure !
Get the picture now ?
Old Jun 22, 2016 | 10:16 AM
  #170
RK4ME's Avatar
RK4ME
The MoCo tells you to use the kill switch because they want you to have both hands on the bars when you shut the engine off. They don't want to get sued because someone lost control of his or her bike while trying to shut the engine off. If that doesn't "compel" you to use the kill switch, then it doesn't. So what?
