so are you saying it almost a wash, the power vs. air resistance?
In aviation, non-turbo charged piston engine aircraft reach that "wash" at about 8500'. Above that at WOT and the plane slows down due to less power. Below that and air density slows the plane down, even with more power. This is referring to true air speed and not indicated airspeed.
Besides altitude, humidity and temperature also play a factor in air density.
So no, very high altitude riding will never overcome low engine power pushing through less dense air. If the bike is turbo charged, it will scream at higher altitudes.
I'm not a Phd in physics so if someone feels I am wrong, please feel free to correct me.
Mt Evans, if my memory is right elevation is slightly under 15,000.
"Slightly under 15,000 feet"? Yeah,by about 800 feet. To the OP's question.............been over Evans,and Pikes Peak,both a little over 14,000 feet. Trail Ridge,which stays at 11,000 to 12,000 feet,for most of it's course. No problems with an injected bike. My carbed shovels used to gasp for air over 8,000 feet in the Sierras,unless you rejetted. But who the hell wants to mess with that?
Brought my boat from okc, to northen newmexico. Altitude on lake I work is over 8000'. Had some performance problems. After some research, found out that all combustion engines suffer from altitude. The numbers that seemed most consistant were a loss of 3% per thousand foot gained. For me, damn near 25%. Just fyi. With gears, you'll be fine. I had to re-prop... twice! Doh!
