Enclosed trailer shopping
Depending on what you're towing the trailer with--I would recommend a dual axle trailer with electric brakes and get a weight distribution hitch with anti-sway bars to keep the trailer the most safe, stable, and versatile as possible.
2: The lighter the better because it pulls easier.
3: No matter how long you get it, you will always wish you had another 2 foot.
4: What size vehicle do you have and what will it pull up and down a mountain?
5: Brakes & a spare.
6: V-Nose and 7' of headroom if you are going to use it for anything more than towing a bike(s).
7: an 8'-6" wide trailer has more wind resistance than a narrower trailer. Take the extra cost in fuel and divide that by the comfort and convenience that a wider trailer will provide you especially if ever thinking about camping out in it.
8: A flat deck trailer will get your two bikes there with the least amount of initial capital outlay and is cheaper on fuel. Sucks for camping out on except if it rains real hard & the ground floods out.
I have 3 different trailers. Two of which I made.
The least expensive LINK: How To Fabricate an Inexpensive Motorcycle Trailer Using an Unwanted Boat Trailer PDF Download
I used a longer home made boat trailer with 3" channel & converted it to a flat deck using 1/4: aluminum plate. It can haul 5 bikes with twin axles & I have pulled it with all of my show material & 3 HD's from Ft. Lauderdale, FL to Sturgis SD & back with a mini-van getting somewhat good fuel miliage.
I have a Featherlite 4926 24' Car hauler and it is slowly morphing from this into this undone project still in progress. It is first a mobile empty full service shop that everything wheels/carried in or out of once the destination is reached.
.jpg)
.jpg)
I would imagine your choice may lie somewhere between the three unless you want to go bigger.
I do remember others saying "damn,I should have gone bigger".
You never know what you might want to haul a few years from now.
Fast: I had considered doing what you did with the boat trailer, as I have an old pop-up camper that's no longer useful for that purpose, so I started taking it apart. But the small single axle and no brakes worried me as far as load carrying capacity and the blowout factor. Storage space in the yard isn't an issue, but the tow vehicle is--my wife's Range Rover Sport is the desired TV, and it has a towing capacity of 7k# for a braked trailer and only 1700# for a non braked trailer. Of course my Cummins Ram can pull any trailer we're talking about, but the idea is for the truck to pull the camper and her Rover to pull the bikes. I know, get a toy hauler...but wife really likes the camper we have and doesn't want to lose living space for garage space. So it's either super-lightweight open trailer like your boat conversion or enclosed with brakes. Or maybe order up a 3500# axle with brakes and use that on the pop-up frame? Decisions, decisions.
As you can see the extra 4 feet make a big difference (7x12 vs 7x16)
With a wide trailer and both bikes already loaded on you should have enough room to put one of these waterproof roof carriers between the bike, bolt it down, than load it it. One that the top lifts off is better than one that hinges. They make long & narrow ones for skis. Get your stuff out of the car and into the trailer. I use the same welded on the bottom nuts with through bolts to mount my wheel chocks so I can move them around as needed and use the same mounting for this storage solution.
