Helmet cameras
Old Jan 30, 2014 | 07:44 AM
  #31
Johnny 5's Avatar
Johnny 5
Honestly, the Gopro is the best one out there IMO.
once you get it down its easy to use. I had mine at sturgis last year, hooked it up to my smartphone and set it up and took some amazing videos, just need to buy more sd cards for recording or turn the quality down from 1080 to 720 or do the pic every couple of seconds, which i might try out this summer on some runs around town and see how it turns out.
never had a problem with the go pro, but the one thing is that the battery is pretty limited but tell me of one camera that can run for the entire ride and not die? turn the wifi off and it will save alot of the battery life. I did a run from Belle Fourche to devils tower and back and it died just after passing the Wyoming Border on the way back with wifi on.
No real complaints there, was a pain that i had to go back and charge my battery but I may either buy another battery and have that charging while i use the other one.
Or since i bought a SG, i may connect it to constant power thru the cig lighter in the fairing depending on how i can hide the cables etc.
I would not attach it to my helmet, its so hard for viewers to actually have a view of the scenery and the trip etc. I believe someone said viewer whiplash, which makes alot of viewers quit watching.
Old Jan 30, 2014 | 02:50 PM
  #32
SquidHead's Avatar
SquidHead
I have a
Contour Roam Contour Roam
that I got second hand. It is super easy to use. The software that comes with it is very simple. It records in HD (1080, 960, or 720). The capacity is great. I record my daily commute which is a little over an hour of recording time in full 1080. I've never had an issue with space or battery life. And it's waterproof as is, no special case needed. It has a laser level function that helps make sure the lens is aligned how you want it.
The only complaints are the mic does not have an external jack, so there's tons of wind noise. I taped a cotton ball over it and that reduced it a lot, but eventually I'll hard wire my own external mic to it. The other is the handlebar mount vibrates so badly that it's useless, so I use the helmet mount instead.
Here's one of my recordings. There are more on my youtube page.
Old Jan 30, 2014 | 06:27 PM
  #33
Monkeymann_916's Avatar
Monkeymann_916
Originally Posted by Johnny 5
Honestly, the Gopro is the best one out there IMO. once you get it down its easy to use. I had mine at sturgis last year, hooked it up to my smartphone and set it up and took some amazing videos, just need to buy more sd cards for recording or turn the quality down from 1080 to 720 or do the pic every couple of seconds, which i might try out this summer on some runs around town and see how it turns out. never had a problem with the go pro, but the one thing is that the battery is pretty limited but tell me of one camera that can run for the entire ride and not die? turn the wifi off and it will save alot of the battery life. I did a run from Belle Fourche to devils tower and back and it died just after passing the Wyoming Border on the way back with wifi on. No real complaints there, was a pain that i had to go back and charge my battery but I may either buy another battery and have that charging while i use the other one. Or since i bought a SG, i may connect it to constant power thru the cig lighter in the fairing depending on how i can hide the cables etc. I would not attach it to my helmet, its so hard for viewers to actually have a view of the scenery and the trip etc. I believe someone said viewer whiplash, which makes alot of viewers quit watching.
Why would you have wifi hooked up while riding?
Dude, every signal u went by it would be attempting to pick it up. If u whr doing it so u cld watch while riding, why not just keep ur eyes on the road, knowing it's recording what ur seeing.
Also, anyone who buys one wld be silly not to buy another battery and external charger with DC input, and also CLASS 10 Cards. Anything less, u video will be grainy looking and he hiccups
Old Jan 30, 2014 | 09:21 PM
  #34
Johnny 5's Avatar
Johnny 5
well first off, i did not have it to watch waht im riding, not sure what kind of idiot would do that. I used the smart phone to show what i was viewing to level my camera to the angle i wanted it to be set at prior to riding. the wifi was left on because one of my buddys GF was the one that turned the camera on and off for me since she was riding behind her boyfriend and didn't have to worry about making sure it was running and all i had to do was start my bike and ride while she climbed on the back of buddys bike, turned it on and put the phone in her purse.
as well, we stayed in a place with power, after all day riding, i would recharge it, no big deal.
and for space, i rode down from canada and recorded all the way. Of course im gonna run out of space.
Old Jan 31, 2014 | 06:36 AM
  #35
jimmers1817's Avatar
jimmers1817
I was wondering what the wifi was useful for. Pretty cool that you can use it as a viewfinder to adjust the camera. That's one limitation of my older gopro. I've been pretty lucky doing it by guesswork but this feature would make it so much more easier and accurate.
Old Jan 31, 2014 | 09:13 AM
  #36
NiteOwlNY's Avatar
NiteOwlNY
I'm a Photographer and have tons of cameras that I rig up for both still and video but mostly I use a GoPro on the bike.
The biggest problem on a Harley is the vibration and the rolling shutter effect you'll get with something like a GoPro. There are ways to combat it either by getting a Neutral Density filter to go over the lens to force a slower shutter speed or the Quad Copter people have a bunch of different "Jelly Killer" solutions. A google search will show you lots of ways to combat it.
If you're truly serious about making videos the mounts that GoPro offer aren't the best solution, they are very cheap and flimsy. I have the Tripod mount adapter so I use regular professional rigging equipment.
Here's a shot of one of my mounts off the side of my old Road King.
Old Jan 31, 2014 | 09:21 AM
  #37
NiteOwlNY's Avatar
NiteOwlNY
I think it's funny how they sold peeps on the fact of using ur phone with the GoPro.
It's an action cam, how can one be extreme kayaking, sky diving, motorcycle riding etc, and be looking at the shot and clicking the shutter.
Keep your hands on you toy and let it do it's thing
The WiFi to your phone or other device is handy for AIMING the camera while setting it up. Without being able to see what the camera is looking at you have no idea what the video will look like until you get back to a computer to review what you shot. It's also great to be able to share photos/video while out on the road. You're not actually using it to snap photos although I keep my phone in a Ram X mount on my bars so I can start/stop the video if I'm not using the wireless controller...
Old Jan 31, 2014 | 10:57 AM
  #38
Monkeymann_916
well first off, i did not have it to watch waht im riding, not sure what kind of idiot would do that. I used the smart phone to show what i was viewing to level my camera to the angle i wanted it to be set at prior to riding. the wifi was left on because one of my buddys GF was the one that turned the camera on and off for me since she was riding behind her boyfriend and didn't have to worry about making sure it was running and all i had to do was start my bike and ride while she climbed on the back of buddys bike, turned it on and put the phone in her purse. as well, we stayed in a place with power, after all day riding, i would recharge it, no big deal. and for space, i rode down from canada and recorded all the way. Of course im gonna run out of space.
Well u have to be a dumb *** not to be able to aim iit in ur direction needed, especially being that it records in wide screen. Use it once if needed. She might have been able to turn it on and off but u continually whr transmitting ur recording to the phone, which obviously uses battery that u don't need to. U don't need to worry if it's recording if you push bottom once and go. It actually has a LED light in 4 places to let u know it's recording, not rocket science.
But hey, to each there own
Old Jan 31, 2014 | 10:59 AM
  #39
Monkeymann_916
And I mentioned this due to you making a statement of the battery being limited
Old Jan 31, 2014 | 11:03 AM
  #40
Monkeymann_916
Jimmers, it's not that ur lucky, it's not that hard to do that's all, that's why GoPro is using it as a selling tool To sell more cameras
