I did the same thing as the OP when I built my first 2 stroke Detroit 4-53. When the governor came apart I watched chunks of piston fly out of the straight pipe. Not fun.
I had a 2-stroke Suzuki a few too many years ago that snapped a con rod which subsequently came through the sump, it stopped quick.
Is it just me, or does that exhaust valve look like it got hot in its center, kinda matching that spot on the piston? Maybe detonation got so bad that it just hammered that one spot until it forced the piston sideways.
Obviously you didn't look at the pic...lol. Stroker pistons don't have much skirt area, so they can flip before breaking when they get that hot. Detonation usually burns a hole/melts the top of the piston. The piston had to be "cherry red" when that happened...it was lean for some reason...or the ignition crapped out and went full advance.
