According to S&S here is what they have to say about the affects of lugging your engine.
"Lugging an engine means putting the engine under an extremely stressful load. A common way to lug an engine is to operate it at an extremely low rpm while the transmission is in a higher gear (for instance, leaving the transmission in fourth gear when it should be in second or third where engine speed is better matched to transmission speed). Lugging causes extreme stress between the rear thrust faces of each piston and the cylinder walls. Small bits of piston skirt can break away causing the rear surface to scuff. The best prevention for lugging an engine (either old or new) is to downshift to a lower gear where the engine runs more freely, and the transmission assists the engine in delivering peak power to the rear wheel."
steel thunder
It is also important not to lug the engine. Lugging an engine means putting the engine under an extremely stressful load. A common way to lug an engine is to operate it at an extremely low rpm while the transmission is in a higher gear (for instance, leaving the transmission in fourth gear when it should be in second or third where engine speed is better matched to transmission speed). Lugging causes extreme stress between the rear thrust faces of each piston and the cylinder walls. Small bits of piston skirt can break away causing the rear surface to scuff. The best prevention for lugging an engine (either old or new) is to downshift to a lower gear where the engine runs more freely, and the transmission assists the engine in delivering peak power to the rear wheel.
I see scoring and scorched over heated areas. Could be from an engine low on oil or ran as hard as as it would go prior to a proper brake in.
It does look like it received brutal use and abuse.
When I was young and stupid I blew up engines and transmissions often. I knew whose fault it was and just called the repair cost " entertainment tax". Same for the traffic tickets.
Yup I see a big inch motor that's had the phuc run out of it with little to no break in period , that engine was beat on from the gate . For those of you who have never seen a high RPM piston failure you just got your first look see .
yeah, I don't think that motor was broke in and or tuned right before beating on it.
though it doesn't look like the piston burned down from being to lean, by looking at the combustion chamber you can see detonation marks in it.. high rpm, excessive pinging for whatever reason, wrong timing, lean, wrong fuel etc.. spelled the end for this motor from the beginning.
Ouch!! I have to agree that I think possible oil starvation and excessive RPM in maybe 1st or 2nd gear. Was there oil in the bike and how much ,was the oil pump functional for that much damage it had to be making one hell of a noise just before failure, to me I would say it was deliberate, maybe he wanted to see how high and how long he could rev it before BOOM !!
If that engine got a 100 miles on it before the happy hand got heavy I'd be shocked . Bigger the motor the more critical that first 1000 miles are and how it's run . Most guys who go big & bad like that just do not do a break in , can't tell you how many go by the old bullshit motto , " Break it in the same way your gonna ride it . They sold several brands of the kit choppers with 100 plus inch motors at the old Indian dealer around 2003 -04 , 3 out of 5 that left the parking lot you'd hear the guy light it up hitting the entrance ramp for the freeway 6 blocks away instead of doing the first 100 miles on city streets like we told them . Within 1000 - 1500 miles without fail those same guys where back with trashed motors screaming , I've seen many a blown motor with that type of piston failure . He got lucky most bend a rod too .
