BDL compensator
Old Feb 5, 2014 | 10:47 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
Originally Posted by Very High Plain Drifter
It has Nylon stops inside you say? Curious how they'll look in 5,000 miles...
i KNOW. THEY ARE VERY HARD they don't even feel like nylon, but the comp doesn't seem to have a lot of travel. so maybe they don't get hit hard. I don't know that this works, I just know the HD ones don't. so I am willing to try what looks good. I'm the beta tester here!!Hope I didn't waste a couple hundred bucks. it does look good on paper at least
Old Feb 5, 2014 | 10:52 AM
Very High Plain Drifter's Avatar
Fingers crossed for ya! I know Nylon is pretty tough - I've bought replacement bearings that had Nylon stays in them, and apparently Ford make (or made) internal engine components out of Nylon. It's not just for your woman's legs!
Even so, although the travel isn't much, the torque will be pretty high...
Old Feb 5, 2014 | 11:55 AM
Rickr01's Avatar
Rickr01
you don't need to remove the inner, loosen the bolt and nut from crank and trans, undo tensioner, and slide the clutch and comp out, vey easy to do. only reason to remove the inner is if you are removing alt cover (rotor)
There's a benefit over the Screaming Eagle comp right there. The Screaming Eagle replacement requires removing the stock rotor. So the BDL unit uses the stock rotors cup that houses the stock springs? I've attached a pic of the stock rotor on the right and the referenced cup I'm referring to.
I'd sure love to see a pic of yours before you button it up.
Old Feb 5, 2014 | 12:36 PM
harleycharlie1992
the comp will just pull in against the washers, and bottom out, so there is no need to remove the rotor. I already had the se rotor in mine, so you have to use some washers, that are supplied in the unit to compensate for chain alignment. there is no need to remove the inner housing. I talked to bdl today and asked about the life of the nylon stops, and they told me that since they released this in 08, they have had no requests for replacement stops. I will post some pics this afternoon
Old Feb 5, 2014 | 12:57 PM
Rickr01's Avatar
Rickr01
I'm still running my stock 2010 comp. I don't think the BDL unit will work with my stock rotor? Don't see how it can. I'd have to check with BDL. It looks like I'd need to replace my rotor with the Screaming Eagle flat version? The spring cup built into the original rotor looks like it would pose a problem with the BDL.
Old Feb 5, 2014 | 01:39 PM
harleycharlie1992
call bdl, 714 693 1313, it will work, really. don't have to change the rotor. the new comp fits right inside
Old Feb 5, 2014 | 01:52 PM
Rickr01's Avatar
Rickr01
You are right. I just emailed BDL and got a response right back from Scott. The compensator is designed to work with either rotor. The fact that you don't have to pull the rotor, would make this a very easy and quick install.
Old Feb 5, 2014 | 02:02 PM
harleycharlie1992
from the time I rolled the bike onto the lift and finished the install (minus the outer cover, no gasket yet!) was 1 1/4 hours and I spent almost 20 minutes getting the shims right for chain alingment. its very easy.
Old Feb 5, 2014 | 03:02 PM
Rickr01's Avatar
Rickr01
Now the question is how reliable is it and how well does it work and absorb driveline shock?
Old Feb 5, 2014 | 03:11 PM
harleycharlie1992
well, thats the 200.00 question. BDL, for the most part makes pretty good stuff. their belt drive stuff is very high quality. the piece seems well made. talking to those guys, and they claim no problems, but they did do a modification to them a while ago due to hanging up on the threaded part. Like I said before, don't know if this works, but I do know the HD SE ones don't (at least for very long) so we gonna find out!
