With Spring slowly getting here,I know I will be needing a new battery.Not sure what brand.Probably the usual Big Crank or the Deka.
Does anybody know if there is a way to see the "Born on Date",of the battery.Serial number or lot number or something so I know that I am getting a "fresh" battery,and not one that has been on the shelf or warehouse for a length of time ? Thankyou
Duh! They are sealed after you fill them with plugs and do not breath at all. How do you think the ones that have acid already in them are done? Clue-It is not by magic.
The AGM batteries that you buy dry are maintenance free. The strip of plugs seal as well as the factory ones. At the factory they are filled then plugged.
It is an analogy to your putting the oil into your motor or the dealer. Makes no difference.
