Filling the trans
Old Mar 20, 2014 | 07:39 PM
just plain john's Avatar
just plain john
The thing is, I had an indy change the fluids while it was in for a tire change. The bike didn't leak a drop before, but as he was totaling my bill he asked if it leaked. Said a transmission seal was leaking. I wonder if they overfilled it on purpose to generate a labor charge?
Old Mar 20, 2014 | 07:43 PM
deadman77's Avatar
deadman77
Originally Posted by seniorsuperglideE8
I suppose you could get out the bike jack raise the bike till it's level, check the fluids, lower the bike. Or why not sit on the bike, bring it vertical off the jiffy stand then reach down and check the fluid?
This is correct
Old Mar 20, 2014 | 09:09 PM
bdtaylor1979's Avatar
bdtaylor1979
They could have spilled some while filling it and/or that much over could be enough to make it come out somewhere. I would take some out to get it down to the correct level and then clean everything up real good with some degreaser or something and keep and eye on it. If you don't see anymore leaks he was probably trying to get one over on you.
Old Mar 20, 2014 | 09:30 PM
dickey's Avatar
dickey
Did you check it hot or cold? It will read a little higher when it's hot.
Old Mar 20, 2014 | 09:34 PM
dickey's Avatar
dickey
I know it's popular to knock dealerships here, but the big advantage is that a tech at a dealership has no motive to screw you,as he gets a flat rate for the job, whereas an indy might.
Old Mar 20, 2014 | 09:58 PM
doug62's Avatar
doug62
Not sure which model you have but my 2013 Touring Models Service Manual states "Insert dipstick into transmission. Thread dipstick IN until O-ring makes contact with case. Do not tighten" It does not state anything about the threads just touching the case but you must screw it in.
Old Mar 20, 2014 | 10:24 PM
Def Mute's Avatar
Def Mute
The two marks on the dipstick are to show low and full. Oil level between the two is acceptable. On, or below the low level mark, you should add oil. Above the full mark, the oil will be spit out of the overflow tube while you are riding. Always check when warm...
Dickey, not meaning to offend, but it is obvious you've never worked as a mechanic (for unscrupulous dealers). I can tell you first hand, that you would not believe the number of jobs I lost because I refused to do the things they told me to do, just to raise the profit level, (of course, that is the nice way of putting it!).
Doug62, the earlier models had/have instructions which differ from yours.
Old Mar 20, 2014 | 10:33 PM
Fishrrman's Avatar
Fishrrman
Back in the EVO days, the tranny on my FXR required something like 20 ozs. So you had to stand the bike upright (I used a brick under the jiffy stand), pour some fluid in, check it with the dipstick, repeat.
But with the '07 Road Glide I have now, the manual says "32 oz." in the transmission. So I just buy a bottle of Mobil1 75w/90 synthetic gear oil, clip the tip off the pointed top, and squirt it into the tranny. Don't even bother to stand the bike up or measure on the dipstick (actually, I believe with the TC96 and six-speed transmission the manual says to check on the jiffy stand now). I just pour the whole bottle in and screw the bolt cap back in. Runs fine 'til the next change...
Old Mar 20, 2014 | 10:35 PM
doug62's Avatar
doug62
Thanks for clarifying this. I was a bit concerned as no one else was raising this point. I read and reread the manual to make sure I was not crazy! Thanks again.
Old Mar 21, 2014 | 09:59 AM
jakenok's Avatar
jakenok
If it needs to be standing straight:
1. Open beer, sit on bike
2. Have prospect one hold bike upright
3. Have prospect two check oil level; add oil if needed
4. Continue to enjoy beer, go for a ride.
