Filling the trans
Old Mar 21, 2014 | 10:05 AM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by bdtaylor1979
Yeah, looks over full. I don't know about yours, but mine takes a full quart and is right on the full mark.
Old Mar 21, 2014 | 12:46 PM
RLH3175's Avatar
RLH3175
I just changed mine yesterday, 96 Ultra Classic, book says 20 to 24 ounces, I put the 24 ounces.
Old Mar 21, 2014 | 04:18 PM
PPBART's Avatar
PPBART
Originally Posted by seniorsuperglideE8
...Or why not sit on the bike, bring it vertical off the jiffy stand then reach down and check the fluid?
Too simple...
Old Mar 23, 2014 | 07:33 AM
just plain john's Avatar
just plain john
Originally Posted by PPBART
Too simple...
I'm not talking about engine oil, I'm talking about the trans dipstick which requires an allen wrench to remove. Not so simple while sitting on the bike.
Old Mar 23, 2014 | 09:40 AM
MNPGRider's Avatar
MNPGRider
If it has the 2 level indicators I would put the bike level on the lift, fill the trans and fill it to the full level on the stick for the bike being upright. Then I would take the bike off the lift and rest it on the side stand and check and see if it shows full at the level indicator for it being on the side stand. If you check it both ways with it showing full both ways then at each level indicator you know you can check it either way.
BD, with all due respect, I think you need to read the owner's manual for your dad's Ultra.
As mentioned before, shortly after your first post, the two marks are for "low" and "full." The level should be in between the two marks, when the bike is vertical, with the dipstick resting on the threads.
John, you have a 2005, which makes it a TC88. Directions and procedures change from year to year, but particularly when an engine change is done, such as 88 to 96, 96 to 103, etc. That's why it's important to read your manual and follow it, and not rely on a forum for a correct answer, when those answering may have a different model, or be ill informed.
The same thing will happen when you check your primary oil level. Some models require the bike on the side stand, others straight up.
As far as your dipstick, loosen it first, then sit on the bike and raise it to vertical, bend over and remove the dipstick, wipe it off, reinsert in and rest it on the threads (Note: it will be at an angle, NOT straight up and down), remove and check. Your oil should also be at normal operating temperature, as per the directions in your manual.
Old Mar 23, 2014 | 06:32 PM
MNPGRider's Avatar
MNPGRider
Just for sh*ts and giggles on this Minnesota day that's only 28 degrees, I went out to the garage, took out the transmission dip stick on my '06 TC88, and leaving the bike on the side stand, checked the transmission oil.
BD, with the bike on the side stand, and the dipstick resting evenly on the threads, which is definitely puts the dip stick at an angle, the dipstick doesn't even touch the oil. However, standing the bike straight up, it registers full.
There is also an "A" at the lower mark, which stands for "Add." The "F" at the upper mark stands for "Full." Just like the owner's manual says. I'm relatively sure that John's '05 owners manual has the same directives as my '06. What does your dad's owner's manual say?
Wrong information is far worse than no information.
Old Mar 23, 2014 | 11:36 PM
bdtaylor1979's Avatar
bdtaylor1979
Yeah, I'm an idiot. For some reason I've been thinking about the engine oil dipstick this whole time lol. But I know on my dyna it says to check the trans with the bike on the side stand and the dipstick resting on the threads and not screwed in. May be different for yours and the op's bike.
Old Mar 24, 2014 | 06:53 AM
just plain john
The pics indicate the trans is overfilled, with the bike upright on a lift and the stick resting on the threads as per the manual. That would explain my sudden trans leak after a recent fluids change.
mchertel
May 25, 2015 08:39 PM
jmn1960
Aug 15, 2012 05:48 PM
VTwinJaxFL
Oct 2, 2011 09:05 PM
langlois1
Jun 28, 2009 02:46 AM
langlois1
May 19, 2008 12:35 PM
