The $1 Harley
Check this:
http://webpages.charter.net/bghouse/Chilly/fxrstuff.htm
). If you're competent on trucks, the Harley shouldn't have any tool related expertise you can't handle (might need to get a few specialty tools). There's a few bigger bolts that should get red loctite, but most should only be blue - so you can get them off again. If it has a cotter pin, I use anti-seize, but just about everything else I loctite. They do vibrate a bit...Lot of different opinions on this, I use torque wrenches. After nearly 40 years wrenching on aircraft, I think I have a pretty good feel, but go without one long enough and you're likely to strip one of those low torque case screws, could probably strip one with a handheld screwdriver. I have 1/4, 3/8, and 1/2" torque wrenches to cover all the values properly.
What's the mileage on your bike; if you posted it, I missed it.
you shouldn't have a problem keeping it going
Check this:
