Oil Change Question
Old Jul 17, 2014 | 09:37 AM
Thumper09's Avatar
Thumper09
I use a plastic gallon water jug. I cut it so that the curved part of the jug fits the contour of my motor around the filter. It fits pretty perfectly. I'm amazed at how well it fits. I even cut a little lip so it curves around the back side of the filter.
catches 110% of all oil. I don't punch any holes. I unscrew the filter and it falls right on the tray I cut from the jug.
I'm going on Shark Tank next week to try and strike a deal with Mr. Wondeful.
Old Jul 17, 2014 | 09:40 AM
smokinfromshootin's Avatar
smokinfromshootin
I am gonna try the beer fox/manila folder idea next time. Lord knows I have enough of them lying around.
Old Jul 17, 2014 | 09:58 AM
LonestarXL's Avatar
LonestarXL
By following someone's suggestion on this forum, I made a nice funnel out of heavy duty aluminum foil, and it worked great. I don't think I spilled a drop. The key is to hold it up against the block under the filter really tight while unscrewing the filter.
Old Jul 17, 2014 | 10:30 AM
Munkee's Avatar
Munkee
I use a gatorade bottle. Its just the right size for my filter.
Old Jul 17, 2014 | 12:37 PM
Brewmany's Avatar
Brewmany
110%? My god man, you've just solved the energy crisis! I would think Mr.Wonderful and his fellow moguls would be fighting each other tooth and nail to get in on your invention. I'd wish you luck but you clearly don't need any.
Old Jul 17, 2014 | 12:43 PM
Thumper09's Avatar
Thumper09
I try not to watch much tv, but I love than dumb show
Old Jul 17, 2014 | 02:32 PM
Def Mute's Avatar
Def Mute
Lay yer bike on it's right side, and place drain pan on the floor under oil filter. Oil will only drip off the oil filter mount into drain pan...
I cut some aluminum flashing, into something that diverts the oil to side of bike, and into a well placed drain pan.
Old Jul 17, 2014 | 02:33 PM
Def Mute's Avatar
Def Mute
This is not a duplicate post, but they told me the last one was...
Old Jul 17, 2014 | 02:58 PM
Iron lHorse's Avatar
Iron lHorse
How about start buying the extra long filter. And then you can poke a hole in the end of it a hour or two before you remove it .
Old Jul 17, 2014 | 04:03 PM
dyna rider's Avatar
dyna rider
Default Oil Filter Mess
The best method I have found cut a 4"x 10" strip out a cheap plastic placemat from Wally World and place it under the filter. I then drill or punch 2 holes in the end of the filter at 6 & 12 o'clock. Put a small container under the end of the cut plastic placemat to collect the oil from the filter. I then walk away and leave it to drain all night. When I go back and remove the filter there is nothing to drip on the front motor mount.
