Need some advice from experienced wrenches, please
I started thinking that it may be a good time to maybe have some better cams installed too.
I am not much of an "engine mod" DIY'er, more of a "bolt-on" kinda guy.
Problem is, I am not too sure of what's involved here. Can I just have some bolt-in cams put in, or will I need to replace push rods, bearings, and flux capacitors?
Seriously though, I called and got a price for the chain tensioner upgrade and would like to consider a cam upgrade as well. My motor is mostly stock, except for the stage 1 a/c and SE slip-on's. I'd just like a little more torque without breaking the bank.
Open for suggestions, thanks.
So, yeah, odds are pretty good that even with a simple, straight up parts swap you're gonna be looking at more to replace than what you originally expect. Just seems that's the way it is and always will be...
Are you planning on doing the work yourself, or paying someone? If you're paying someone, the labor cost shouldn't be much different to change the cams as well as the tensioners, since it's already going to be opened up. Obviously you'll have to buy the cams for a couple hundred bucks. While it's open, it would be a good idea to upgrade the inner cam bearings to Torrinton B148s. The bearings will run about $15 for the pair. If doing the work yourself, you'll need to get the tool to remove/replace them. As far as pushrods, you can reuse the stock rods if your new cams have the same base circle as the stockers, which they most likely would. If going this route, the top end (rocker assembly) will have to be removed to remove the pushrods. This requires more labor, but saves on the cost of adjustable pushrods. Or you can cut out the stock rods, replace with adjustables and save on the rocker box labor. That's up to you. I reused my stock pushrods.
I would probably also recommend replacing lifters while you're in there. I used the V-Thunder lifters from Comp cams for $14 each, and they have worked just fine.
It really isn't hard to do. I watched the S&S video several times, read my service manual until I was absolutely sure I understood the process, I researched and asked questions here, and when I was ready I took my time and followed the directions. It was the most in depth wrenching I had done, it went smoothly enough, and I was pretty proud of myself when it was done.
And the new cams really woke up the bike.
