brake lever
Old Jan 7, 2015 | 09:30 PM
elivicki's Avatar
elivicki
6th Gear
Default brake lever
does anyone know how or what kind of grease or oil that will fit inside of the tiny space to use on my brake level plunger? the lever won't push back out enough all the time so the brake light stay on
Old Jan 7, 2015 | 09:37 PM
QC's Avatar
QC
If your master cylinder piston is sticking, I would suggest a rebuild instead of treating a symptom. JMHO.
Old Jan 8, 2015 | 01:13 PM
enodrano's Avatar
enodrano
I have the same issue with mine. The plunger slides in and out of a rubber seal. Over time the plunger shaft/seal dries out. I use a paintball gun oil. It is 100% synthetic, non-toxic, won't freeze and won't harm o-rings or seals. It works good but I have to re-oil it every few months. Any food safe lubricant should work. The food safe part is not important on a motorcycle but they are designed for o-rings and seal usage.
Also, you should take the hand controls apart to get good access to plunger.
Old Jan 8, 2015 | 09:09 PM
elivicki's Avatar
elivicki
6th Gear
thank you for that advice I look up this stuff call inox and with the needle straw it came with from the harley dealer i was able to penetrate right into the side and around the plunger and now it like brand new again
harleyfiremedic
May 22, 2016 02:01 AM
Dangit
Electrical/Lighting/Alarm
Mar 30, 2015 04:53 AM
stevemaman
Sep 11, 2014 05:46 PM
JustDave71
May 21, 2010 11:10 PM
HilllBillly
May 5, 2010 03:47 AM
