HD Air Pump
Old Feb 28, 2015 | 02:49 PM
roadwarrior1545's Avatar
roadwarrior1545
Default HD Air Pump
I recently bought a 2009 Road King. I have read several articles and posts about air pressure in the shocks. My question is has anyone used a manual pump other than the HD pump. The ones Dennis Kirk sell only go to 30 or 35 lbs. The HD manual recommends 50 lbs for my setup riding 2 up. Does anyone know other companies that sell small pumps with a gauge on it for less than the HD pump that reads more than 35 lbs.
Old Feb 28, 2015 | 02:51 PM
roadwarrior1545
I guess I should have stated that cost less than $60.00
Old Feb 28, 2015 | 03:07 PM
Uncle Larry's Avatar
Uncle Larry
Someone just listed a "used" pump for ( I think ) ... Do a search!
https://www.hdforums.com/forum/touri...-and-case.html
Old Feb 28, 2015 | 10:31 PM
dfwhockey17's Avatar
dfwhockey17
This one works great!
http://www.progressivesuspension.com...tal-gauge-pump
Old Mar 1, 2015 | 08:55 PM
martin10's Avatar
martin10
I have a like new one I would let go. PM me if interested.
Old Aug 26, 2015 | 01:01 PM
Orb's Avatar
Orb
Hi
I bought and just receive the Progressive Suspension air gauge. Works perfectly and is less costy than the HD one. I read that Progressive made it for HD somewhere in this forum. Make sure you select the GP3-60 model up to 60psi (max pressure for my RKC is 50 psi according to manual).
Link : http://www.progressivesuspension.com...ini-gauge-pump
Hope that helps not too late.
Old Aug 26, 2015 | 03:38 PM
fidel's Avatar
fidel
i just take a small bicycle pump 5.00$
Old Aug 26, 2015 | 05:16 PM
Frostbite's Avatar
Frostbite
I use this one:
http://www.craftsman.com/craftsman-c...id=00911586000
Old Aug 26, 2015 | 05:19 PM
TriGeezer's Avatar
TriGeezer
Better be careful. Most bicycle pumps have an air capacity greater than a motorcycle air chamber.
Old Aug 26, 2015 | 05:25 PM
TriGeezer's Avatar
TriGeezer
The Harley pump is $50, and will read up to 60 pounds. Has s built in gauge snd pressure release. The pressure release is a very convenient way to get the perfect pressure.
IMHO...you can't go wrong with the HD pump...and there is not much to save for the functionality.
Again...my humble opinion..your's may vary.
