Forks crooked
Old Mar 4, 2015 | 09:28 AM
dbeach2014's Avatar
dbeach2014
6th Gear
Default Forks crooked
When I am riding my bike straight down the road it loos like my forks are pointing a little to the right. is this possible or an illusion?
Old Mar 4, 2015 | 11:00 AM
dfwhockey17's Avatar
dfwhockey17
It is possible, but more likely in the handlebars. Your handlebars have rubber bushings from the factory and they can let the bars twist a bit. Start by loosening up the riser bolts and try 'resetting' the handlebars to square in the triple tree and see if that helps.
Old Mar 4, 2015 | 01:34 PM
enodrano's Avatar
enodrano
Forks can twist especially if your running without a fender. If twisting is an issue you can always add a fork brace for added stability. There is a couple of things I would check.
1. Is there any unusual wear on your front tire? If so that could be a indication that something is off.
2. While riding in a straight line, briefly take your hands off the bars and see if the bike noticeably tracks to the left or right.
Also, as already stated, check the handlebar alignment with the triple trees. If everything checks out then I would say this is just an illusion.
goose222
2014-2024 Touring Models
Jul 25, 2015 06:27 AM
FLaVaZ
Sep 15, 2014 03:34 PM
AlexVDL
Feb 6, 2014 10:29 AM
ericf
Sep 25, 2007 08:32 AM
mhughes600
May 15, 2006 02:08 PM
