208 road king tps error
Old May 28, 2015 | 07:35 PM
trowfaz's Avatar
trowfaz
Stage II
Default 208 road king tps error
Hello,
I am new to this site and new to Harley Davidson. This is my first Harley so forgive my ignorance. I have an 08 Road King I purchased this about 3 years ago and love this machine. I put a pigtail on the battery for the trickle down charger. Now I have a check engine light and I found the code is for the TPS. I cleared the code but the check engine light came right back on. I bought a Harley maintenance manual but there is no TPS in the manual. Does anyone have the correct solution?
Thanks
Old May 28, 2015 | 09:29 PM
Ed Ramberger's Avatar
Ed Ramberger
There is a bulletin out detailing TPS errors on the electronic throttle control bikes. 2008 touring is especially susceptible because the seat can hit the ECM and disrupt the connections.
I believe it is TT418A. The initial bulletin had you replacing only a few sockets. THe revised has you replacing many.
Before you do anything, read it.
My friends bike went to forced idle just as he merged into heavy highway traffic. Thank goodness he is a motorcycle cop and knew how to handle the situation. I replaced all his sockets at the ETC and he hasn't had a problem since.
Look this bulletin up and see how your bike compares. By 10K miles many would show the symptoms.
Old May 30, 2015 | 04:51 PM
trowfaz's Avatar
trowfaz
Stage II
Default 2008 road king tps error code
Hey Ed
Thank you for that information. It seems that I have a lot of homework to do. I am really frustrated with Harley. I purchased the 2008 Toouring Service Manual for about $90. I got it and was excited to work on this and, hopefully, fix this myself. Apparently to do any electrical diagnostics, I have to buy a seperate manual. Long gone are the Chilton Days.
Old May 30, 2015 | 06:07 PM
Ed Ramberger
The connectors you need are only about a buck each. You'll need a quality crimp tool. With a lot of these, it turns out to be bad connections at the throttle body between the pins and the sockets.
meek chiz
May 11, 2017 12:01 AM
steveculp
May 6, 2012 02:24 PM
nascar7613
Apr 8, 2012 03:56 PM
nvrenough
Apr 18, 2010 10:40 PM
Hx3
Apr 15, 2009 11:07 AM
