Day maker lights
Old Jun 5, 2015 | 07:24 AM
Stacy73's Avatar
Stacy73
Default Day maker lights
I have a 2014 FLHTK with 22k. While cleaning the bike the other day I noticed the day maker headlight and running lights had condensation in them. Took it to the dealership and they called HD. HD agreed to change the lights no argument. I'm wondering if this is a new problem or just bad luck.
I can't find any type of crack or problem with the lights. Have had several days of rain riding and washing.
Old Jun 5, 2015 | 05:05 PM
enodrano's Avatar
enodrano
The lights have rubber seals to keep moisture out. Those seals can dry out over time. Also if they are not seated right they can cause problems. Remember just because they are sealed does not mean they are waterproof. When you wash your bike you should never wash the lights, controls, and gauges with a strong stream of water. Just gently rinse them off. Also, let those things thoroughly dry before starting the bike again. The strong stream can penetrate places water should not enter and water can short circuit electrical components.
Hopefully you just got some bad lights and the new ones will fix the issue.
Old Jun 7, 2015 | 11:23 AM
Budda109's Avatar
Budda109
Default moisture
I have 2011 set of day maker lights. I get the moisture in the spots not the headlight. Just on the inside center of the glass. When I start out on a ride they seem to be dry. Then after a time riding I will stop and it will take a day to dry out again. Can you just buy the rubber seals that dry out? Not the end of the world but want to make it right.
Old Jun 8, 2015 | 07:26 PM
Stacy73's Avatar
Stacy73
My spots also have moisture in them. HD is also replacing them. Just waiting for the lights to come from Milwaukee, as it is being taken care under warranty. Since they are ORIGINAL EQUIPMENT THEY HAD TO BE ORDERED.
jcannady
Sep 17, 2013 09:15 AM
tasman117
Sep 14, 2013 05:22 PM
GPHDXLC
Apr 27, 2011 07:03 PM
masterblaster
Mar 17, 2008 08:43 PM
larry5h
Oct 11, 2006 02:09 PM
