Replacing stage 1 intake back plate
Old Jun 9, 2015 | 11:43 AM
marcocast's Avatar
marcocast
Contact IB to have your account opened
Default Replacing stage 1 intake back plate
Good morning guys.
Excuse my question that may be common sense to some, but I am new to the performance world and do not want to mess up my bike.
So here it goes
I currently have a 07 super glide FXD with with a stage 1 SE AC (came like that from dealership). I am wanting to change the backplate to a chrome instead of the the black plate it came with.
What needs to be done in order to have this swap, is it a simple swap or do I need new gaskets, o rings, and tuning?
I also have a Vance and Hines short shot exhaust if that information is needed.
I have never taken off the back plate. Does it require alot of mechanical knowledge to delve past the air filter?
Old Jun 9, 2015 | 11:48 AM
nevil's Avatar
nevil
Can't get any simpler. Aside from the right size tools and blue loctite, no gaskets or tuning needed.
Old Jun 9, 2015 | 11:52 AM
marcocast's Avatar
marcocast
Awesome thanks.
I am always scared to mess with my Harley. Its only till I get a little grease on my hands that I start mustering up courage to start unbolting stuff.
Thanks for the speedy response
Old Jun 16, 2015 | 02:21 AM
Re-load's Avatar
Re-load
Tools you'll need:
Hex 5/16 for the air cleaner cover
Torx 27 for the 3 torx screws that attach the filter to the backplate
Tequila shots x 3
pull off the black rubber breather tubes after the filter is off to expose the breather bolts.
7/16 socket for the 2 breather bolts
1/2 socket for the 3 bolts that attach the backplate to the TB
You might need a gasket from the backplate to the TB, I know when I took my SE Stage 1 off, the gasket came off in chunks.
oldbikenut
Apr 13, 2015 05:23 PM
martin10
General Topics/Tech Tips
Dec 6, 2014 06:27 AM
HDV-GLIDE
Oct 9, 2012 07:01 PM
FLoTR
Oct 13, 2010 09:58 PM
js1268
Apr 7, 2007 05:35 PM
