Problem with Kuryakyn Forward Controls
Old Apr 28, 2007 | 05:21 PM
pdiddles's Avatar
pdiddles
Default Problem with Kuryakyn Forward Controls
I posted this in the Dyna forum, but I thought it should here too.
I just received my new forward controls in the mail - ordered from the Ebay store Eastern Performance Cycles. Anyway, I really need to be studying for some final exams I have coming around the corner, but who wants to wait when they have a new toy. So I ran down to the garage and started my instal. After basically completing the entire install, I got on the bike to determine if the liked the angle of the shift peg. I stepped on the peg and the tranmission downshifted, but when I released the shifter it didn't come back up. It appears that the shift lever is too tight, and the transmission can't pull the shifter back into position after you shift. I removed the forward control assembly from the bike and tried to work the shift lever back and forth, and even rotated it around several time to see if I could loosen up the action, but it hasn't changed at all. Did any of you guys have a similar problem, and if so how did you fix it. I may be able to add some lubricant, but it doesn't appear to be something you can disassemble. Any ideas would be great - thanks in advance.
JDolinski
May 14, 2011 04:51 PM
EvilWayz
Ironhead
15
Feb 25, 2010 06:40 PM
EvilWayz
Ironhead
Dec 12, 2009 01:19 PM
pdiddles
May 1, 2007 11:06 PM
dgbook
Mar 15, 2007 04:05 AM
