Screwed up big time
Old Jul 24, 2015 | 09:56 PM
apblingAEW's Avatar
apblingAEW
Default Screwed up big time
So, I put some highway pegs on my wife's 15 street Bob. I used some stainless bolts. I went out there just now to take them off because I'm going to touch the brackets up some...and the bolts twisted off flush w the frame. Not sure if it galled or because the frame was a little warm or what. So I slowly drilled it out and tried to use my extraction tool. And of course that snapped off. So now I have 2 stainless bolts snapped off, one of them with an extraction bit snapped off it in.
Any advice?? Does there exist a bit that can drill this extraction bit out?
Old Jul 24, 2015 | 10:10 PM
QC's Avatar
QC
If you can find a carbide drill, and I don't mean a concrete drill, that would do it.
Old Jul 24, 2015 | 10:19 PM
apblingAEW's Avatar
apblingAEW
I found that online. Might have to pony up and buy a bit. Would cobalt do it?
I'm not sure what to do here. I'm not sure why they backed out a few turns then stopped and twisted off. I'm really worried about trying to take the other side off.
Old Jul 24, 2015 | 10:21 PM
IdahoHacker's Avatar
IdahoHacker
There's another thread going on about fixing top end clicking noises. One of the fixes requires drilling hardened steel. A member mentioned that a cobalt drill bit from Sears wouldn't even mark it, but a carbide drill bit from Harbor Freight went through it "like butter".
Just a thought.
Old Jul 24, 2015 | 10:24 PM
QC's Avatar
QC
Cobalt will not do it.
How square is the end of the broken extractor? What size bolt are we talking about?
Old Jul 24, 2015 | 10:35 PM
apblingAEW's Avatar
apblingAEW
The bolt is 3/8. When you say square... Do you mean flush? I'll snap a pic in a few.
Old Jul 24, 2015 | 10:36 PM
apblingAEW's Avatar
apblingAEW
Also I do not see a carbide bit from HF
Old Jul 24, 2015 | 10:42 PM
QC's Avatar
QC
Here's alink to a drill:
http://www.ebay.com/itm/5-16-Carbide...item1e8de6d632
I mean does the extractor have a relatively flat surface where it is broken so you have half a chance of getting the drill started straight?
Old Jul 24, 2015 | 10:43 PM
apblingAEW's Avatar
apblingAEW
Yes. It's flat.
Old Jul 24, 2015 | 10:45 PM
apblingAEW's Avatar
apblingAEW
Also. Just tried the other side. First bolt out like butter. 2nd one is 1/4 the way out and it just freezes up. I think heat is being generated when it turn and it snugs up. It's not like bad threads. I'm backing it out, it tightens up. If I go to turn it back in its right there too.
