Help With Steering wobble
Old Aug 23, 2015 | 03:16 PM
Jolly_Roger's Avatar
Jolly_Roger
Stage IV
Default Help With Steering wobble
Good Day,
I have a 1973 FLH with a Friendship II California Sidecar, which I have usd since 1984. In the last 2 years, steering wobble (Death Wobble) has gotten worse when the sidecar is empty and my speed reaches 30 mph. I know original sidecar units came with an adjustable triple tree (45690-69) but I guess these are expensive and rare. Has anyone tried the aftermarket steering Dampers (like 46700-60) ?
Thank you,
Jolly Roger
Old Aug 23, 2015 | 03:39 PM
ZROADSTER's Avatar
ZROADSTER
Yep ! They work pretty well . Mine is adjustable with a 4 or 5 position setting . My first Wide Glide which has a narrow 21" front tire felt a little squirrely at 100 MPH so I went from a 80/90/21 front tire to a 90/90/21 which is much taller & wider . That helped a lot but the steering damper really made all the difference in the world . Bike now feels like its on rails even with high side winds . Much more stable at any & all speeds !
Old Aug 24, 2015 | 11:22 AM
etreulich's Avatar
etreulich
Default Steering damper
I had a 96 ultra that I had a California sidecar on for a while. I added the steering damper because like you I would get the wobble. It took care of the problem. I drove the rig cross country with the damper and the trim motor and never had a problem. I was also way over weight with all kinds of camping gear ,6 gallon extra fuel tank...
I did scrub off a rear tire in 5000 miles but it was a metzler that was a softer and stickier tire anyway . Good luck,Eric
SOCALHD
2014-2024 Touring Models
11
Mar 15, 2016 10:39 PM
Reece64
Aug 2, 2014 07:59 PM
Capt O
Jun 19, 2009 01:07 PM
les63
May 3, 2008 06:50 AM
hugos06flhtci
Sep 2, 2006 11:33 AM
