front tire wobble @ 32 mph
Old Sep 1, 2006 | 07:55 PM
hugos06flhtci's Avatar
hugos06flhtci
Default front tire wobble @ 32 mph
06 flhtci with 6,200 mile at 32 mph my front tire has a slite wobble in it i just want to know anyone has the same wobble it's been to the shop 2 time they say they can not find the wobble i'm going to the shop on saturday to ride a used flh to see
Old Sep 1, 2006 | 10:24 PM
Zap's Avatar
Zap
Default RE: front tire wobble @ 32 mph
ORIGINAL: hugos06flhtci
Do you have this wobble with both hands on the bars? Mine will sometimes do this if I'm riding no handed at slow speed, but I think nearly everyone I've had would do it. Taking hold with both hands will stop it. With that said, I can bury the speedometer with no problems.
Old Sep 1, 2006 | 10:32 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Stering stem Fall-Away and stem nut torque would be the first to check.....
Next would be the balance, and after that would be the true of the wheel (Especially if you have laced wheels)......
After that, (If that all checked out) would be the motor/chassis alignment....
Old Sep 1, 2006 | 11:09 PM
lacedwheels's Avatar
lacedwheels
I don't have the wobble on mine but I have had it on others. It Usually turns out to be the tire when you have a low speed wobble.
Just try this as a troubleshooting measure only, add an extra 10 lbs of air and see if it wobbles at the same speed. If the wobble goes away or lessens, its the tire. THEN be sure to deflate to the proper pressure
Old Sep 2, 2006 | 05:04 AM
hugos06flhtci
thank you for the info and yes riding with my right hand on the handle bars it wobble
Old Sep 2, 2006 | 08:19 AM
wnogood's Avatar
wnogood
My old fatboy did that and on closer inspection, the front tire was coming apart! There was a split between the center tread ribs that went about 2/3 around the tire. The dealer replaced it under warranty, and sure enough, it was fine.
nogood o~`o
Old Sep 2, 2006 | 10:17 AM
Hackd's Avatar
Hackd
ORIGINAL: wnogood
My old fatboy did that and on closer inspection, the front tire was coming apart! There was a split between the center tread ribs that went about 2/3 around the tire...
Oooooooooh! Now that would've been ugggggglyyyyyyyy! I don't wanna even imagine having a front tire shred at highway speeds.
Old Sep 2, 2006 | 11:33 AM
midwesttom's Avatar
midwesttom
Do search on here this has been talked about alot. Mine was doing that as well only when verly holding the bars at 40. Dealer tightened the stering head bolt and checked the fall away. The wobble quit but still slight vibration at that speed. But mine was only on deceleration and varely holding the grips. There has been alot on the general forum and some good info. Good luck Tom
JohnnyRebKY
Jun 7, 2014 09:02 AM
rockon
May 22, 2012 12:01 PM
mmgogos
Jul 16, 2008 09:55 AM
Jughugger
Sep 6, 2007 07:21 PM
maltezebluez96
Sep 15, 2006 09:30 PM
