handlbars have the shakes
Old Jul 14, 2008 | 09:10 PM
mmgogos's Avatar
mmgogos
Default handlbars have the shakes
Hi , its a 03 rk with 10 k on her. at a certain speed only the bars get the shakes. it about 38 mph. do I need a new tire , bearings, or blance?? thanks mike
Old Jul 14, 2008 | 09:22 PM
campincowboy's Avatar
campincowboy
Default RE: handlbars have the shakes
Start with checking tire first for any blems, just raise it up and spin while closely inspecting. Balance problems usually only occur at highway speeds, probably not at 38 mph. Also check that caliper is not binding causing brakes to drag. Feel bearing after ride to see if there is excess heat which indicates bad bearing. Good luck.
Old Jul 14, 2008 | 09:30 PM
Mars's Avatar
Mars
check steering head tightness as well and lube the head. tire pressure is the first thing that comes to mind though.
Old Jul 15, 2008 | 01:53 PM
bgkv77's Avatar
bgkv77
If my tire pressure gets low that is usually about the speed I&nbsp\\;will feel&nbsp\\;some shakes.
Old Jul 16, 2008 | 09:55 AM
07SG's Avatar
07SG
An '03 with only 10k miles? She's probably shaking because of the foreign concept of being ridden.
ringer1969
2014-2024 Touring Models
Sep 2, 2017 11:19 PM
Rmuller
Feb 6, 2011 05:09 PM
phatsanders
Sep 3, 2009 09:28 AM
Capt O
Jun 19, 2009 01:07 PM
Maniac
Oct 9, 2007 02:28 PM
