General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
The weight ratings for conventional oil vs. synthetic oil are the same so you should not be concerned with leaks unless your engine already leaks oil. Synthetic oil is slipperier which helps components last longer. Its viscosity also breaks down much slower than conventional oil so in theory you could extend your oil change window. Just remember that viscosity breakdown is only half the reason you need to change your oil. The other half is how dirty the oil gets. It does not matter how long the oil lasts if it is filled with dirt and debris.
The general opinion is synthetic oil is far superior. The only downside to it is when it's used in new engines. New engines need a break-in period for moving parts to find their groove. Synthetic oil is so slippery that parts can break-in properly. You engine is at 50k, I would go ahead and make the swap.
Thank for the recommendations for syn oil. I found J@P cycles caress my Rev tech Synthetic oil. Ill be staying with my brand . I hate to use 20/50 in the primary but I be leave Syn oil in the primary would be good for the compensatory.
Use the Syn oil!
In motorcycles, its biggest advantages isn't really the longer service period between changes, but the superior lubrication on startup of a cold engine, where most of your engine wear actually occurs.
As far as 'break in' period and synthetic goes, everyone has their opinions... I have never seen scientific proof of synthetic oil doing any harm or otherwise. 'Break in' is mainly about bits of metal or debris left over from manufacturing finding their way to your oil filter or magnetic drain plugs more than anything else.
FWIW, I bought a new Subaru last year, it comes with fully synthetic oil in the crankcase, and per owner's manual, you aren't ever allowed to use dino oil in it at all.
