Sportster pipes
Old Sep 14, 2015 | 04:17 AM
Cgads's Avatar
Cgads
2nd Gear
Default Sportster pipes
I'm riding a 95 XLH883, I've owned it for about 4 months now & she runs great but I'm currently running pipes without the crossover connection, how much of a difference would this make? Either in sound or performance?
Old Sep 16, 2015 | 07:06 AM
grbrown's Avatar
grbrown
The cross-over pipe was discovered by BSA motorcycles back in the '60s, IIRC, by accident! It gives improved torque in the low/mid rev range, where most of us ride. It didn't take too long before every twin-cylinder bike on the planet was fitted with them, across all brands. So you are giving away a little extra performance, I suspect also that two separate pipes are a little noisier than pipes with a cross-over. If you look at a current Sportster you will see that they also have a cross-over pipe, but it is hidden away down low behind the mufflers.
Old Sep 16, 2015 | 10:25 AM
enodrano's Avatar
enodrano
The crossover pipe equalizes the exhaust gases allowing the engine to run more consistently. Modern vehicles of all types most likely have an OEM crossover. It's usually hidden on motorcycles now compared to the visible one on the stock 95 883. You can get the same results with an aftermarket 2 into 1 exhaust system. When running 2 into 2 pipes you will only lose a negligible amount of performance so unless your racing professionally, I would not worry about it.
Killerman#1
Oct 10, 2013 09:27 AM
HD-Dream
Nov 18, 2011 04:30 PM
fuelmoto
Fuel Moto / Jackpot Mufflers
Feb 3, 2010 01:54 PM
blackedout08
May 25, 2009 03:49 PM
69sport
Ironhead
Aug 29, 2007 11:01 AM
