Radio - Info Center
Old Dec 21, 2015 | 06:41 PM
John H.'s Avatar
John H.
Stage I
Default Radio - Info Center
My radio, clock and all information on my info center is blank if I let the cycle sit for a while, like overnight. I can take the fuse out and put the same fuse back in and everything works. I wonder what's going on. Could my battery be getting weak?
Old Jan 23, 2016 | 07:56 AM
Backdraft161's Avatar
Backdraft161
I would put a volt meter on it. Check what the voltage drops to when cranking. If it drops below 10 volts you need a new battery.
Hope this helps
Old Jan 25, 2016 | 12:34 PM
chromelens's Avatar
chromelens
I would check and see if the radio has the current software update.
Old Jan 27, 2016 | 10:50 AM
CVO SG's Avatar
CVO SG
Registers, logs in, ask for assistance
Hasn't been back since
Old Jan 28, 2016 | 10:46 AM
Backdraft161
Also check in the "how too" section at the top of the forum. Good read for what is happening with your bike.
Hope this helps
harleyd1500
Jan 25, 2018 02:56 PM
WNMORE
2014-2024 Touring Models
11
Nov 6, 2017 05:22 PM
07yellowglide
Audio Systems
Sep 11, 2012 07:16 PM
Fustercluck
Sep 1, 2011 08:40 PM
