Should I be concerned?
Old Mar 23, 2016 | 12:58 AM
Rastoff's Avatar
Rastoff
4th Gear
Default Should I be concerned?
I did a search and didn't find the answer. I'm sure this has come up before so, I apologize, but I need to know.
I just purchased an '06 Ultra Classic.
I was told that the twin cam motors, prior to '06, had an issue with the spring cam chain tensioner. I was told that they could wear out early and cause the cam chain to destruct.
I've also heard that there is an upgrade to a hydraulic tensioner.
First: Is this really a problem?
Second: If it's a problem, will just replacing the plastic tensioner pad be enough?
Third: Is it worth it to upgrade to the hydraulic tensioner and new oil pump?
Old Mar 23, 2016 | 05:14 AM
Ron750's Avatar
Ron750
This has been discussed ad infinitum. How many miles on your bike? It usually isn't a problem until 30k. My dealer will inspect them for $125, then put that towards replacement, of you need them. Some guys replace them, some upgrade to the SE Hydraulic, some go to gear drive.
If you plan on keeping your bike, and have 30k do an upgrade. Did you have a mechanic inspect your bike? There are other issues like engine mounts, caliper rebuilds, depending on mileage, and previous maintenance.
Old Mar 23, 2016 | 09:04 AM
Rastoff's Avatar
Rastoff
4th Gear
Thanks for the info. A mechanic had looked at the bike, but I don't know if he specifically looked for this issue. Inspecting the cam tensioner pads should only take a few minutes
The bike has about 32k on it so, I will definitely look into this
Old Mar 23, 2016 | 11:06 AM
TurboChris's Avatar
TurboChris
You have options. If they are worn......you can replace them with factory pads, or you can get aftermarket ones by Cyco. Less than $100
http://www.harleydavidsontensioner.com/
Or you can do the complete cam chest upgrade.......but it's spendy.....about $500 in parts and another couple hundred min in labor. If you aren't putting a ton of miles on the bike or you're a casual rider you may want to consider just replacing the pads if they're worn or just inspecting them every 5-10k miles.
Old Mar 23, 2016 | 11:39 AM
Rastoff's Avatar
Rastoff
4th Gear
Thanks for that link. Very useful info there.
EarlB
May 26, 2019 08:28 AM
LQQK_OUT
Engine Mechanical Topics
Sep 24, 2018 09:44 AM
b1gj0n44
May 8, 2017 10:18 AM
Madcop
Aug 26, 2014 10:48 AM
rjo3491
Aug 7, 2014 10:22 PM
