engine codes
Old Apr 4, 2016 | 07:51 PM
UFO8MyCow's Avatar
UFO8MyCow
Default engine codes
I have been having issues with my 06 Street Glide throwing codes and speedo and tach freezing up
I have been having issues since last spring when I tore the entire bike down for paint and powder coat. When I pout it back together I hooked up 2 of the connectors inside the fairing wrong but everything else seemed ok after I found the issue
I have checked the codes and am not sure where to go from here. I understand that the speed sensor is a common fault but I am also wondering about the TSSM.
P = ECM/ICM(Electronic Control Module)[EFI] /Ignition Control Module[Carbureted])
P1356 Rear Cylinder No Combustion
U1097 Loss of SpeedometerSerial Data to ECM
S = TSM/TSSM (Turn Signal/ Security Module)
B1121(TSM) Left Turn Output Fault
B1122(TSM) Right Turn Output Fault
U1255 Serial Data Error
U1097 Loss of Speedometer Serial Data to ECM
SP = speedometer
U1016 Loss of ECM Serial Data
U1064 Loss of TSM/FSFM Serial Data to ECM
T = tachometer .
Old Apr 6, 2016 | 12:55 AM
UFO8MyCow's Avatar
UFO8MyCow
update.
I reaized that the b1121 and b1122 were because of the led turn signals I installed so that is not an issue.
First I pulled the VSS out and it was clean all I got on the white towel was oil residue.
Cleared all codes and went for a 1/2 mile test ride and still had codes
I replaced the TSM with a new one from the dealership and went for a 1/2 mile ride and I was still getting codes.
Returned the TSM to the dealership and bought a new VSS and installed and went for a 70 mile ride and am still getting the following codes
What is the next step? an new ECM?
Bigdad68
Apr 28, 2024 05:40 PM
htoler
Fuel Moto / Jackpot Mufflers
Sep 16, 2018 05:32 PM
Mich
Sep 26, 2014 07:24 AM
bobros
May 27, 2008 05:52 AM
cdem02
May 3, 2007 05:34 AM
