motor question 06 eletra glide
Old Aug 17, 2016 | 06:17 PM
hammer232323's Avatar
hammer232323
5th Gear
Default motor question 06 eletra glide
i bought a 06 electra glide has from what i can tell a stage 4 kit on it how can i find out what has been done to the motor? i do not want to tear it apart to find out what was done.I called the dealer i got it from and he has no record or knows where or who did the work
Old Aug 18, 2016 | 10:11 AM
dfwhockey17's Avatar
dfwhockey17
The only way to know for sure is to tear it apart....
Old Aug 18, 2016 | 11:49 AM
White Ice's Avatar
White Ice
What leads you to believe it has a stage 4? Stage 4 usually refers to turbos, blower, nitrous, etc.
Generally accepted definitions
Stage 1 - intake, exhaust, tuner
Stage 2- Stage 1 + cams
Stage 3 - Stage 2 + headwork....blueprinted, porting, etc.
Stage 4 - As described avove.
Old Aug 18, 2016 | 06:57 PM
dfwhockey17
^You forgot the big bore stage (stage 3), then stage 4 (headwork). A lot of times stage 3 and 4 are combined since the heads are pulled for bigger jugs. That is how he is at stage 4.
FWIW, I hate 'stages' strictly for this reason. I understand the need to try to classify different levels of mods/work; but between the HD forums and my Audi forums I am all staged out!
Old Aug 18, 2016 | 09:32 PM
hammer232323
5th Gear
going off what my dealer said when i brought it in for dyno and tune. it has compression release on both heads screaming eagel heads air cleaner jugs and trans. i also found yesterday my dyno jet 3 was not working i unpluged it and pluged it back in and was working fine. i zip tied it together so it will not unplug in the future.
btw thanks for your responses. kinda sounds like i will never know. but i have a nice bike that i love to ride
Old Aug 19, 2016 | 05:49 PM
White Ice's Avatar
White Ice
So what are the dyno results?
big-gun
Engine Mechanical Topics
Sep 28, 2014 09:12 AM
Aylor70
Nov 15, 2012 07:57 AM
Andy_fxdwg
Oct 11, 2012 07:37 AM
anubisss
Jul 1, 2009 01:01 PM
Silverearl
Jun 7, 2007 12:37 PM
