General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
My 07 FXDC sometimes backfires through the breather... I added anew aftermarket breather and then it started so I figured it just needed to be re-tuned.
Backfires as it's trying to start, or after it starts and on choke?
If you have a CV, bottom your A/F screw(count the turns, write down) back it out 1 1/2 turns, if a Mik do same but back out 2 full turns, then restart, (If S&S , no idea.)
Note:CV a/f screw controls fuel amount, Mik a/f screw control air volume
Check intake manifold to cylinder head for air leak.
Check intake manifold seal for tears, fitment on carb throat.
Check for binds on choke cable, fully opens when pulled.
Check float valve, float level.
