Ironhead A place to talk about Ironheads.
What causes backfiring thru the carb?
Old Oct 5, 2011 | 05:04 PM
Frito Bandito's Avatar
Frito Bandito
6th Gear
Default What causes backfiring thru the carb?
I'm not at the end of my rope yet, but getting close! What causes backfiring thru the carb? Point gap wrong, mis-adjusted valves, intake leak, or just the general lack of ability of the doofus, lame, all thumbs mechanic (that being me). One again, thanks for your patience and input~
Old Oct 5, 2011 | 07:14 PM
shepdog's Avatar
shepdog
what carb are we dealing with here? in my experience its usually a lean condition, either a intake leak or a carb that needs richend up a bit,
Old Oct 5, 2011 | 07:21 PM
scottfisher's Avatar
scottfisher
+1.
s
Old Oct 5, 2011 | 07:29 PM
Jackie Paper's Avatar
Jackie Paper
Intake valve leak (check with compression gage). dwell off which affects timing(carefully set points and check dwell to be sure they are correct) adjust timing correctly. (hope your cams are somewere near stock so timing will be stock) Make sure carb does not flood setting for 10-15 minutes with motor off and petcock open. Read plugs for how close mixture is. Be sure advance is correct and working. Sparkplug wires are good (check resistance and check wet in dark for bleed) Remember it will run correct if its set correct.?HA
Old Oct 5, 2011 | 08:36 PM
piniongear's Avatar
piniongear
The first thing I would suspect is the ignition timing, and I would look for a 'too far advanced' setting.
Do the ignition timing correctly using a timing light and see if that does not make the backfiring stop.
pg
DFD
Apr 10, 2018 11:38 AM
edjhover
EVO
May 24, 2016 11:29 PM
bigjayree
EVO
Sep 14, 2015 04:05 PM
1sandking1
EVO
36
Aug 7, 2013 09:58 AM
TXbobber
Exhaust System Topics
Oct 21, 2012 09:03 AM
