Wont run after loose intake
Old Oct 25, 2012 | 08:37 AM
1sandking1's Avatar
1sandking1
Default Wont run after loose intake
I posted this in the softail section, maybe its better here? Thanks for any info
https://www.hdforums.com/forum/softa...se-intake.html
Old Oct 25, 2012 | 10:02 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
When the intake was loose your bike was running in a real lean condition.
When you fixed he intake you now have to re-jet/adjust the carb as you no longer have the lean condition.
Old Oct 25, 2012 | 10:57 AM
1sandking1's Avatar
1sandking1
Plugs always looked good, also running the the jets that S&S suggested. I am thinking the loose intake happened during my last ride, because I did not notice it before. I am going to pull the carb and check the jets to make sure they are clean and check the float. Thanks for the info.
Old Oct 25, 2012 | 10:59 AM
monkeyboy22's Avatar
monkeyboy22
I'm guessing that you took the carb off to inspect/clean the intake seals? Moving that carb around a bit may have dislodged something in the carb and gummed up the works. Pull it apart and inspect/clean that also.
Edit: Well, I see you beat me to it by a couple of minutes.
Old Oct 25, 2012 | 11:45 AM
1sandking1's Avatar
1sandking1
Correct, I did remove the carb twice. Now that I recall, I did notice fuel sitting in the intake when I removed it both times, its gotta be a carb issue............... I HOPE! Thanks guys.
Old Oct 25, 2012 | 12:03 PM
texashillcountry
Dirt don't hurt
Let us know what you find.
Old Oct 25, 2012 | 03:56 PM
1sandking1's Avatar
1sandking1
Ok, pulled the Carb and did not notice anything obvious. Cleaned everything inside anyway. Reinstalled everything and it fired right up. But 10 minutes later, I fired it again for the heck of it and same damn ****. Turned the gas off while it was running and it smoothed out, turned the gas back on and it ran like crap again. Is the float level off or something? This is driving me nuts! Thanks guys so far
Old Oct 25, 2012 | 05:26 PM
1sandking1's Avatar
1sandking1
Called S&S to see if they had any ideas. He had me spray the intake seals to see if they are leaking. I used brake clean, but no idle change. I checked the float level and its about 1/8" beolow the gasket surface as he mentioned it should. Had me look for the o-ring on the accelerator pump shaft, its there.
Can my jetting be off? I am running a 295 main and a 72 pilot as suggested by them for use with my Hooker pipes. What else can it really be? My plugs are coming out BLACK and puffing black smoke. HELP!! Thanks
Old Oct 25, 2012 | 06:12 PM
texashillcountry
Dirt don't hurt
Check your fuel/air mixture screw.
Old Oct 25, 2012 | 06:13 PM
texashillcountry
Dirt don't hurt
With black smoke and plugs black you are running entirely too rich.
